I am a beginner in electronics. I know a few basics. I have a multimeter that I set to 200 Vac for testing.
I have a distiller I have been using for 10+ years now and recently it stopped working. I am trying to determine where the fault is so I can replace the part. The company that made the distiller went out of business years ago, so I can't call them for support.
What isn't working is:
Heating element isn't starting.
Fan isn't spinning.
The boiler tank floater switch is working as water flows in when it drops.
There is a floater in the holding tank that appears to be working as, when I move it the relay clicks on/off.
I believe the issue is either with one of the switches, Mainpower/Fan/Water or the relay?
Here is what I confirmed:
- It's getting power from wall, as lights are on and certain components work.
- Upper Switch Heater Control is getting 120v
- Lower Switch Water Control is getting 120v
- When I test power on the reset switch, between 2 & 1 or 4 & 3 I get 0 volts. Which I am assuming I should get 120v on each? So an upstream fault?
I am looking for guidance on what components to test and how. Any help would be appreciated.
