Thank you, so very much, for continuing to help and teach me. You are pulling together the things that I have learned and helping me to apply them practically. It is great fun. I appreciate you!
I would not be so quick to assume the engineer who laid out the PCB didn't know what they were doing
That is a point worthy of remembering… That is, that the benefit of the doubt goes to the design engineer.
Schematics almost never resemble the physical layout of the circuit, that wouldn't make any sense at all, in many cases you'd end up with a schematic that is a nightmare to follow like the one you drew, or a circuit that doesn't work properly because it's laid out for form rather than function.
I take it that you meant a theoretical person submitting a theoretical schematic, as oppose to suggesting that what I had submitted had some nightmarish failing on my part. I, of course, did not submit a schematic; I submitted a drawing of the board layout, which I had drawn in situ, for the specific purpose of sorting out the workings of the circuit.
As I mentioned earlier, or thought I mentioned earlier, in every single LED backlit TV I've worked on that had backlight problems, the problem was one or more faulty LEDs. I have not yet ever come across a bad driver board, which of course does not mean it can't or doesn't ever happen.
There are several points in play, in this regard…
- I surely have not discounted your experience, opinion, or counsel, as to the likely fault being the LEDs.
- I chose to investigate the board, first, because I find the voltage which powers the LEDs (41.6VDC) to be low (IMO,) in comparison to what my research suggests is typical. More on this to follow.
- I found it less likely that all of the LED strips had simultaneously developed at least one faulted LED, thereby producing a total blackout. More on this to follow, too.
- It is also my workflow practice to follow the circuit through from beginning to end. This works for me, because I get a better understanding of the working of the circuit (which improves troubleshooting), I am more likely to find the upstream cause of the fault (instead of just replacing a downstream damaged component, powering the repaired DUT and blowing the same component, again,) and I am less likely to miss something along the way. I learn more, too, which is fun.
- Disassembling the screen looks to have pitfalls, which I desired to bypass, if taking it apart is not absolutely required.
- With more experience, I may become confident enough to check the LEDs, as the very first step.
Additional Board Testing
- I took voltage readings on the LED Driver IC (OB3353CP.) It does not have any voltage on the Gate (output) pin. I measured the other pins and can provide those numbers, if they would be helpful.
- Accordingly, I did not find any voltage on the MOSFET gate. As before, the MOSFET Drain is at 41.6VDC.
Additional LED Testing
- I disconnected the LED connector and powered them at 41.6VDC/0.2-0.6A, directly, through the cable. No illumination resulted. The PSU did not register any current draw.
- Because I am working without certainty as to the needed LED voltage and current and thinking the circuit would provide it, naturally via its design, I repeated the test by jumping the MOSFET Drain/Source with a current limiting resistor. Again, no illumination.
More To Follows
- LED Voltage; 41.6VDC… I think that it is typical to assume that each LED requires about 3V. If so, that would mean there are maybe 12 to 14 LEDs. Because a matrix would require a certain arrangement, I am guessing there are three rows of four LEDs. Does that seem reasonable for a 32” TV?
- Is 41.6V a reasonable voltage to find driving the LEDs, even though it does not seem to fit my research?
Other Considerations
The owner reported a full failure, without any flash, bang, or boom. She turned the TV off. When she turned it back on, there was only the black screen.
As said, all of the LED strips dropping at least one LED, all at the same time, does not seem likely. So, we have several possibilities…
- All of the LEDs are on just one, single in-series string and just one failed LED was all that was necessary to black out the whole screen?
- The OB3353CP has lots of monitoring functions and is not outputting the Gate voltage, because it has detected some LED fault? Or, it has failed, simultaneously, also?
Next Steps
I imagine that you are going to suggest that there is no way to avoid disassembling the screen. If so, I would watch some YouTube videos on the process, but what tips do you have? Is there anything else I should check, before proceeding with the screen?
Please hang in there with me. I am very confident that we will find the problem. Thanks, again.
