I picked up a Tek 576 a few days ago and I've been trying out all of the controls on it and I'm having problems with the Collector Voltage selector switch. The switch has an inner and an out shaft and an inner and outer knobs. When you pull out on the inner knob it lets you select the series resistance in the collector circuit and when you leave the knob in it's supposed to allow to change collector voltage. When you change the collector voltage you rotate the inner shaft (without pulling the knob out) and the mechanism inside then rotates the outer shaft and that moves the pointer that points to the voltage labels.
Everything works fine when I pull the knob out and adjust the resistance however when I try to change the voltage the knob is very hard to turn, in fact, I have to use so much force that the knob slips on the shaft and the shaft never rotates. I replaced the factory knobs with knobs from a parts unit HP scope that uses larger set screws but even they slip on the shaft. The only way that I can rotate the shaft is to take the knobs off and use a pair of pliers but even that is difficult and it's chewing up the shaft. I have already opened up the chassis and lubricated both the detents (in both sections of the switch) and all of the contacts. It didn't help. I can rotate the switch to all four voltage positions using pliers so the switch isn't physical blocked but it is VERY hard to turn.
Any suggestions?
