Author Topic: Need help with component identification for LG LED TV  (Read 584 times)
Offline DIODEKIDTopic starter
« on: April 22, 2021, 09:15:21 pm »
Hello everyone,
I was wondering if anyone could help me identify a component that is located on the motherboard of an LG, 55GA6400 LED TV. I attached photos of the part in question. There are several of these same exact components located on the board and they have individual numbers identifying each one. The part was initially loose and fell off of the motherboard-or it may have had some assistance :). The TV turns on but there is no image. Please let me know if you can ID the part. Thanks in advance!!
Offline amyk
Re: Need help with component identification for LG LED TV
« Reply #1 on: April 23, 2021, 12:12:21 am »
That appears to be a block of foam with a conductive outer wrapping for grounding and reducing interference.
If it was already loose before disassembly, it may have shorted out and damaged something. Otherwise it should have no effect on operation.
The following users thanked this post: DIODEKID
Offline shakalnokturn
« Reply #2 on: April 23, 2021, 12:15:10 am »
Soft foam or rubber covered with a conductive textile.
They're used for grounding / shielding, here to make contact between main board ground plane and back of TV screen.
They're often not absolutely required for functionality, having them floating loose however is bad, they could create destructive short circuits.
Amyk beat me to it...
Offline sean0118
« Reply #3 on: April 23, 2021, 01:36:58 am »
I know it's not what you asked, but it's likely the fault is caused by faulty backlights or mainboard and unrelated to the EMC foam bits. Have a read through these:
https://www.badcaps.net/forum/showthread.php?t=57964
https://badcaps.net/forum/showthread.php?t=65957
Just be careful, there are voltages in there that can kill you.  :-/O
« Last Edit: April 23, 2021, 01:39:08 am by sean0118 »
