Electronics => Repair => Topic started by: Ookpik on March 18, 2019, 12:20:22 am
I am fixing this chassis for a friend and am having trouble. I have deduced that the problem is most likely the voltage regulator however I have no idea which part or parts comprise the voltage regulator.
The chassis is the type that was used as a replacement chassis for 1980’s video arcade games. Unfortunately, no documentation seems to exist for this chassis. The closest schematic I have located can be found Here (https://docs.google.com/viewer?a=v&pid=sites&srcid=ZGVmYXVsdGRvbWFpbnxtdHBhY2lmaWNvfGd4OjViMDVkZTBiMTk5YmE1Y2I&fbclid=IwAR2yTcYpTh0L6JNIaT7_iS1oP9DGfS7HHHHUVO9QoI0Z8641DQk7Sq2rmVQ).
A larger image of the chassis can be found Here (http://www.tranquilitybasearcade.com/chas.jpeg).
(https://klovimg.com/images/2019/03/17/chas1.jpg)
Any help would be greatly appreciated! :)
I did a cap kit on the chassis. No change. :(
If anyone else has any suggestions they would be greatly appreciated! :)
hum check on the aluminum plate, i think the Q05 is a regulator or the flyback driver, do i see some U02 near the plate ???
your closest schematics is for speakers not for an monitor
