I recently acquired a free Meguro MO-1252 35MHz oscilloscope. It’s been several decades since I used an oscilloscope and that was an early digital one I used more for data acquisition than signal analysis, so my skills weren’t much more than novice then. The scope seems to function and responds to volts and time per division when I apply an AC signal and play with the basic controls. Triggering controls function as best I can tell. The problem I don’t seem able to remedy is the trace is limited to the right side of the screen, about one division right of center. When I use the horizontal position control to move it left, it hits a wall and the trace partially compresses against it. I can move it to the right completely off the screen. It’s like the position control is misaligned with the CRT.
I did find a link on the forum to a manual that looks to be applicable to this scope. Apparently, this is a highly cloned scope, represented in the manual as a Hung Chang OS-635. I am a mechanical guy, not a sparky (no offense. I’ve work around EE’s my whole career and am jealous they understand my mechanical stuff better than I understand theirs), so I struggle with much of the manual, but with some guidance I might be able to make sense of some of it. I figured it might be wise to ask for help before I start turning things inside the box.
Any thoughts on what I should try first?
