Been a long time stalker on this forum but haven't really posted anything. I have a set of AKAI RPM-800 studio monitor speakers and one that just all of a sudden stopped working. before, if the speaker was turned on, you could hear an audible hiss that's present on both both speakers, but now this one doesn't have any hiss or audio outputting. It does have power going to the transformer and the led light is on.. I have a basic workbench and am still learning so please forgive me. I do have a Instek GDS-1054b coming. I was going to go for the Rigol 1054z but this was a little cheaper and seemed to have a much better FFT section.
I have tested the preamp section (which is on a separate board) and it does seem to be working. I just used my cheap signal generator with a sine wave at 15khz to test the output of the preamp to the input of the power amp board and it came through fine, even adjusting the level using the volume potentiometer looks to be good.
It does have 2 TDA7294 DMOS amps. One for the tweeter and one for the woofer.
I'm worried it may be the transformer which has a dual secondary of 22VAC*2 and 13.5VAC*2 as it looks like it's feeding 2 separate full wave bridge rectifiers to output DC. I don't think I'm testing this thing correctly.
I'm not sure I'm testing the transformer properly and wanted to make sure I am. Like I said, I'm still learning and haven't really had much experience.
I would take it to an electronics shop, but 1 - got the set new for $200 which is a steal and have had them for years, 2 - There are no local repair shops around my area, and 3 - I really wanted to use this as way to learn more about electronics. Any help would be appreciated.
