Author Topic: Need help with Samsung NZ64H57477K Induction Hob repair  (Read 6419 times)
Offline flattermann1822Topic starter
« on: May 30, 2018, 05:28:08 pm »
My induction hob doesn't work anymore.
The hob doesn't switch on when touching the power button. No response. No LEDs or something lights up.
I guess i found something abnormal on the power supply pcb. Fuses are ok but 12V are not stable and 5V are low with some peaks. More see attached scope pics.
1. Is this normal?
2. What can cause such effects?
3. Do someone know where to find shematics or part information?
4. Where can i buy a replacement?
Thanks
Offline bingo600
Re: Need help with Samsung NZ64H57477K Induction Hob repair
« Reply #1 on: May 30, 2018, 05:43:27 pm »
I have saved 2 induction hubs w. touch , for a couple of friends.
By just blindly replace all Electrolytic caps.
And use 105 deg instead of the lousy 85 dec caps in the replacement.
/Bingo
Online wraper
  • Country: lv
« Reply #2 on: May 30, 2018, 06:23:30 pm »
/Bingo
85oC does not mean lousy, as well as 105oC does not mean good  :palm:. Not to say, all electrolytic caps except big high voltage cap seem to be LOW ESR type and of all are rated for 105oC.
« Last Edit: May 30, 2018, 06:29:38 pm by wraper »
Online wraper
  • Country: lv
« Reply #3 on: May 30, 2018, 06:27:10 pm »
If you don't have ESR meter to check them, try replacing this capacitor first.
Offline bingo600
« Reply #4 on: May 30, 2018, 06:40:03 pm »
How can you tell that  .. You didn't see the brand of the caps i changed  :palm:  |O
And the Touch PSU PCB was just under the cooking plate, getting a lot of radiated heat.
Weird comment ...
The one where you actually suggests something was way better.
/Bingo
« Last Edit: May 30, 2018, 06:44:37 pm by bingo600 »
Online wraper
  • Country: lv
« Reply #5 on: May 30, 2018, 07:39:08 pm »
I did not say anything about caps you changed  :palm:. And you did not even say about what caps you replaced in your repairs but said to replace "lousy" 85oC caps. I just said that temperature rating does not tell anything about capacitor quality. Not to say that mentioning 85oC is not even applicable to this case as there are none of such present on the PCB.
https://www.samyoung.co.kr/download/new/NXA.pdf
« Last Edit: May 30, 2018, 07:42:18 pm by wraper »
« Reply #6 on: May 30, 2018, 09:22:34 pm »
thanks for your reply.
i don't have ESR meter. So I replaced CP04 (47uF/50V/105°C) with no success. I ordered the other electrolytic caps and will replace them too.
Online wraper
  • Country: lv
« Reply #7 on: May 30, 2018, 09:36:32 pm »
I hope you ordered low ESR type except big cap. General purpose 105oC capacitors won't last. Now rethinking about those waveforms, did you capture those while PSU was disconnected from the rest of the circuit? It may fail to work properly without any load attached. SMPS needs a minimum load and there does not seem to be any dummy load resistor present on the PCB.
I would suggest to measure while it is connected to the rest of the circuit or attaching some dummy load to at least one of the rails. Something that would sink at least 0.5W, say <47R on 5V rail or <200R on 12V rail.
« Reply #8 on: May 30, 2018, 09:49:50 pm »
Yes, i ordered low esr type caps.
Yes, i did not attach any load to 12V and 5V rail. I will do the test tomorrow with load again
Gesendet von meinem HUAWEI VNS-L31 mit Tapatalk
« Reply #9 on: May 31, 2018, 06:08:27 pm »
I did the test with load on the dc outputs. See attachment. Outputs are still not stable.
« Reply #10 on: June 01, 2018, 06:52:45 pm »
/Bingo
I replaced the other electrolytic caps too, but still no stable output on 12V and 5V rails. What can I do next?
Online wraper
  • Country: lv
« Reply #11 on: June 01, 2018, 06:57:39 pm »
Hmm, I looked on 5V waveform and it's really weird and only 160mV mean. Check that rail. Maybe diode is shorted or something like that.
« Last Edit: June 01, 2018, 07:01:27 pm by wraper »
« Reply #12 on: June 04, 2018, 08:21:20 pm »
I didn't read your post. But I really found out something strange with a diode in the 5V circuit.
I have no Vf and Vr when testing it with diode tester. And its shorted in both directions.
I didn't find a part for the replacement with the printed information. Which diode can I use?
Online wraper
  • Country: lv
« Reply #13 on: June 04, 2018, 08:42:41 pm »
You wrote SB2100 yourself, this is a part number. You could use basically any Schottky diode with at least 2A 50V ratings.
http://www.smc-diodes.com/propdf/SB2100%20N0154%20REV.A.pdf
« Reply #14 on: June 09, 2018, 09:33:57 am »
I soldered a new SB2100 Diode and now there is something to see on the 5V rail. But both rails are still not stable. See attachment.
Outputs are loaded with 150Ohm on 12V and 47Ohm on 5V rail again
What's the next i can check?
« Last Edit: June 09, 2018, 09:41:04 am by flattermann1822 »
Offline Shock
« Reply #15 on: June 10, 2018, 12:15:00 am »
The 12V rail looks happier now without the short, does it look even better without the 5V loaded? IC501 could be a problem, the 5V rail is not being regulated properly. Plus the secondary filter capacitors are still suspect if a few years old.
« Reply #16 on: June 10, 2018, 09:43:21 am »
I did some further load measurements, see attached document point 2.7.
I have already replaced all electrolytic capacitors with new low ESR ones.
Online wraper
  • Country: lv
« Reply #17 on: June 10, 2018, 09:58:37 am »
Yeah, IC501 might be dead, it should not overshoot 5V.
« Reply #18 on: June 10, 2018, 10:49:33 am »
How can I find out a suitable replacement for IC501.
Which kind of IC is this?
I didnt find a part with the printed text on the IC.
Online wraper
  • Country: lv
« Reply #19 on: June 10, 2018, 11:16:43 am »
It's some sort of 1117 series 5V LDO vreg in DPAK (TO-252) package made by a lot of manufacturers, though I don't recognize which one exactly. But it does not really matter. You could use 1117 from any manufacturer, say NCP1117DT50 from On semi or LM1117IDTX-5.0 from TI.
« Reply #20 on: June 10, 2018, 11:59:03 am »
I replaced IC501 with TS7805CZ LDO but the waveforms are almost the same  :-\
Online wraper
  • Country: lv
« Reply #21 on: June 10, 2018, 01:03:04 pm »
Does it peak to 6V as well? Then there might be something wrong with how you are measuring. BTW 7805 is not suitable replacement because of much higher minimum voltage drop on it.
Online wraper
  • Country: lv
« Reply #22 on: June 10, 2018, 01:06:27 pm »
OK, This waveform was quiet misleading. There are 2 high high peaks on 5V waveform which make voltage measurement wrong. There is something sketchy going on with either how you are probing or your scope. Enable bandwidth limit at least.
« Last Edit: June 10, 2018, 01:08:02 pm by wraper »
Offline Shock
« Reply #23 on: June 10, 2018, 02:06:04 pm »
Just curious what the pinout on the LVR you soldered in was.
« Reply #24 on: June 10, 2018, 02:29:30 pm »
Yes there was something wrong with my scope. Besides the peaks there was a dc offset which is not real.
So after scope self calibrating and enable bandwith limit here the waveforms again. Still with 7805 and both rails loaded.
Peaks on CH2 are caused by a bad probe, sorry.
