Author Topic: Need help with Samsung NZ64H57477K Induction Hob repair  (Read 2677 times)
Offline flattermann1822
« on: May 30, 2018, 05:28:08 pm »
My induction hob doesn't work anymore.
The hob doesn't switch on when touching the power button. No response. No LEDs or something lights up.
I guess i found something abnormal on the power supply pcb. Fuses are ok but 12V are not stable and 5V are low with some peaks. More see attached scope pics.
1. Is this normal?
2. What can cause such effects?
3. Do someone know where to find shematics or part information?
4. Where can i buy a replacement?
Thanks
Offline bingo600
Re: Need help with Samsung NZ64H57477K Induction Hob repair
« Reply #1 on: May 30, 2018, 05:43:27 pm »
I have saved 2 induction hubs w. touch , for a couple of friends.
By just blindly replace all Electrolytic caps.
And use 105 deg instead of the lousy 85 dec caps in the replacement.
/Bingo
Online wraper
  • Country: lv
« Reply #2 on: May 30, 2018, 06:23:30 pm »
/Bingo
85oC does not mean lousy, as well as 105oC does not mean good  :palm:. Not to say, all electrolytic caps except big high voltage cap seem to be LOW ESR type and of all are rated for 105oC.
« Last Edit: May 30, 2018, 06:29:38 pm by wraper »
Online wraper
  • Country: lv
« Reply #3 on: May 30, 2018, 06:27:10 pm »
If you don't have ESR meter to check them, try replacing this capacitor first.
Offline bingo600
« Reply #4 on: May 30, 2018, 06:40:03 pm »
How can you tell that  .. You didn't see the brand of the caps i changed  :palm:  |O
And the Touch PSU PCB was just under the cooking plate, getting a lot of radiated heat.
Weird comment ...
The one where you actually suggests something was way better.
/Bingo
« Last Edit: May 30, 2018, 06:44:37 pm by bingo600 »
Online wraper
  • Country: lv
« Reply #5 on: May 30, 2018, 07:39:08 pm »
I did not say anything about caps you changed  :palm:. And you did not even say about what caps you replaced in your repairs but said to replace "lousy" 85oC caps. I just said that temperature rating does not tell anything about capacitor quality. Not to say that mentioning 85oC is not even applicable to this case as there are none of such present on the PCB.
https://www.samyoung.co.kr/download/new/NXA.pdf
« Last Edit: May 30, 2018, 07:42:18 pm by wraper »
« Reply #6 on: May 30, 2018, 09:22:34 pm »
thanks for your reply.
i don't have ESR meter. So I replaced CP04 (47uF/50V/105°C) with no success. I ordered the other electrolytic caps and will replace them too.
Online wraper
  • Country: lv
« Reply #7 on: May 30, 2018, 09:36:32 pm »
I hope you ordered low ESR type except big cap. General purpose 105oC capacitors won't last. Now rethinking about those waveforms, did you capture those while PSU was disconnected from the rest of the circuit? It may fail to work properly without any load attached. SMPS needs a minimum load and there does not seem to be any dummy load resistor present on the PCB.
I would suggest to measure while it is connected to the rest of the circuit or attaching some dummy load to at least one of the rails. Something that would sink at least 0.5W, say <47R on 5V rail or <200R on 12V rail.
« Reply #8 on: May 30, 2018, 09:49:50 pm »
Yes, i ordered low esr type caps.
Yes, i did not attach any load to 12V and 5V rail. I will do the test tomorrow with load again
Gesendet von meinem HUAWEI VNS-L31 mit Tapatalk
« Reply #9 on: May 31, 2018, 06:08:27 pm »
I did the test with load on the dc outputs. See attachment. Outputs are still not stable.
« Reply #10 on: June 01, 2018, 06:52:45 pm »
/Bingo
I replaced the other electrolytic caps too, but still no stable output on 12V and 5V rails. What can I do next?
Online wraper
  • Country: lv
« Reply #11 on: June 01, 2018, 06:57:39 pm »
Hmm, I looked on 5V waveform and it's really weird and only 160mV mean. Check that rail. Maybe diode is shorted or something like that.
« Last Edit: June 01, 2018, 07:01:27 pm by wraper »
« Reply #12 on: June 04, 2018, 08:21:20 pm »
I didn't read your post. But I really found out something strange with a diode in the 5V circuit.
I have no Vf and Vr when testing it with diode tester. And its shorted in both directions.
I didn't find a part for the replacement with the printed information. Which diode can I use?
Online wraper
  • Country: lv
« Reply #13 on: June 04, 2018, 08:42:41 pm »
You wrote SB2100 yourself, this is a part number. You could use basically any Schottky diode with at least 2A 50V ratings.
http://www.smc-diodes.com/propdf/SB2100%20N0154%20REV.A.pdf
« Reply #14 on: June 09, 2018, 09:33:57 am »
I soldered a new SB2100 Diode and now there is something to see on the 5V rail. But both rails are still not stable. See attachment.
Outputs are loaded with 150Ohm on 12V and 47Ohm on 5V rail again
What's the next i can check?
« Last Edit: June 09, 2018, 09:41:04 am by flattermann1822 »
Offline Shock
« Reply #15 on: June 10, 2018, 12:15:00 am »
The 12V rail looks happier now without the short, does it look even better without the 5V loaded? IC501 could be a problem, the 5V rail is not being regulated properly. Plus the secondary filter capacitors are still suspect if a few years old.
Multimeters: Fluke 87V, 117, 27/FM     >>> Fluke 51/52 Thermometer Parts Required <<<
Oszilloskopen: Rigol DS1054Z, Phillips PM3065
« Reply #16 on: June 10, 2018, 09:43:21 am »
I did some further load measurements, see attached document point 2.7.
I have already replaced all electrolytic capacitors with new low ESR ones.
Online wraper
  • Country: lv
« Reply #17 on: June 10, 2018, 09:58:37 am »
Yeah, IC501 might be dead, it should not overshoot 5V.
« Reply #18 on: June 10, 2018, 10:49:33 am »
How can I find out a suitable replacement for IC501.
Which kind of IC is this?
I didnt find a part with the printed text on the IC.
Online wraper
  • Country: lv
« Reply #19 on: June 10, 2018, 11:16:43 am »
It's some sort of 1117 series 5V LDO vreg in DPAK (TO-252) package made by a lot of manufacturers, though I don't recognize which one exactly. But it does not really matter. You could use 1117 from any manufacturer, say NCP1117DT50 from On semi or LM1117IDTX-5.0 from TI.
« Reply #20 on: June 10, 2018, 11:59:03 am »
I replaced IC501 with TS7805CZ LDO but the waveforms are almost the same  :-\
Online wraper
  • Country: lv
« Reply #21 on: June 10, 2018, 01:03:04 pm »
Does it peak to 6V as well? Then there might be something wrong with how you are measuring. BTW 7805 is not suitable replacement because of much higher minimum voltage drop on it.
Online wraper
  • Country: lv
« Reply #22 on: June 10, 2018, 01:06:27 pm »
OK, This waveform was quiet misleading. There are 2 high high peaks on 5V waveform which make voltage measurement wrong. There is something sketchy going on with either how you are probing or your scope. Enable bandwidth limit at least.
« Last Edit: June 10, 2018, 01:08:02 pm by wraper »
Offline Shock
« Reply #23 on: June 10, 2018, 02:06:04 pm »
Just curious what the pinout on the LVR you soldered in was.
« Reply #24 on: June 10, 2018, 02:29:30 pm »
Yes there was something wrong with my scope. Besides the peaks there was a dc offset which is not real.
So after scope self calibrating and enable bandwith limit here the waveforms again. Still with 7805 and both rails loaded.
Peaks on CH2 are caused by a bad probe, sorry.
Online wraper
  • Country: lv
« Reply #25 on: June 10, 2018, 03:36:17 pm »
Did you attach the load after replacing the diode?
« Reply #26 on: June 10, 2018, 06:05:34 pm »
TO220, more see attachment
You mean the original load (system PCBs)? Yes i did attached it. But hob does not seem to work again. I did not connect sensors and coils at this time.
« Reply #27 on: June 10, 2018, 06:07:45 pm »
I did some further test with the desoldered LDO. In my opinion it still works.
Offline Shock
« Reply #28 on: June 12, 2018, 06:17:53 am »
This is what I would do. I'd not connect the actual load until the supply looked functional (it may be damaging the supply). The resistors however, as long as low current is the safer route.
I'd replace the LVR and order a couple of the proper LDOs (as they fail in stupid ways).
Resolder that transformer connection closest to the 5V input. Clean up the solder splashes and flux.
I'd decide it if it was worth physically isolating the 5V and 12V from the feedback/error circuit and make sure it's perfect by pulling and checking the small caps for capacitance and DC resistance.
With the 5V regulator and the 12V dual diodes out I'd measure resistance between the 5V input and ground. Swap the leads over and measure ground to 5V input. Then do the same on the 5V output to ground (both ways) and then check the 12V to ground in both ways. If the feedback/error circuit is isolated as well this should build confidence there is no weird stuff going on in the secondary (and you can always apply a DC voltage source to the PCB and test it).
Then recheck the previously replaced diode and test the dual diodes.
At this stage if nothing conclusive I'd install the new LDO and dual diode again and power the supply and take another scope measurement unloaded and loaded with a small current.
If still getting 6V on the output of the 5V LDO with a small load I'd check the Y suppression caps between the primary and secondary. Then lastly start checking the components in the feedback/error circuit.
An ESR meter (even a cheap one) would be handy to know how bad things were on those replaced caps.
« Reply #29 on: June 12, 2018, 06:04:55 pm »
Thank you for your reply. i will order new LDOs, a cheap ESR meter and try to work through the points.
Online wraper
  • Country: lv
« Reply #30 on: June 12, 2018, 06:08:18 pm »
I don't think there is any issue with LDO. The problem was with crappy measurement, not IC.
Offline Shock
« Reply #31 on: June 13, 2018, 12:34:29 am »
I don't think the LDO is necessarily going to fix it. It could be the 5V input is voltage/ripple, or current sensitive and cheap to get a couple and use one as a replacement.
The question is what shorted the diode. It appears from the oscilloscope measurement it's switching at around 8KHz with current issues.
But anyway continue on Wrapper with what you think should be done next, I was only suggesting what I'd try.
« Last Edit: June 13, 2018, 12:37:04 am by Shock »
« Reply #32 on: July 12, 2018, 03:58:19 pm »
I resoldered transformer connection. Clean up the pcb and have some new LDOs here
dual Diodes (DS01) and DS2 are fine and I have a cheap ESR Meter here.
Did you mean that I now desolder all caps, RS05,RS08 and RS11 to check that there is high resistance between 12V/GND and 5V/GND?
I tried to create the circuit diagram of the secondary. Not sure if TR1 and ICS02 have the correct symbols. At the moment ICS01 and DS01 are not mounted.
Offline Shock
« Reply #33 on: July 13, 2018, 02:38:00 am »
Last diagnosis was it looks to be either the circuits being pulled down or still suffering from a regulation issue. The 6V out of a 5V regulator is a concern because between ground and out should read 5V.
By measuring between the rails and ground you can determine if a low resistance path exists which could be loading the output. The other idea is to isolate the transformer and feedback circuit and inject DC or AC to check the regulation, in a similar way that you did it out of circuit. Or check component by component. When the regulators or diodes are out it allows you to easily measure the input side of the regulator to ground or the output side to ground.
To put it clearer, not a lot of components in that circuit should be drawing sizable current to ground, only the regulator which has to do it in order to lower the voltage. Aside from the diodes it's just the resistors in the feedback circuit.
Check the Y suppression caps (marked CY01 CY02) as well.
Confirm DC regulation is perfect, confirm secondary components not applying adverse load or affecting feedback, confirm optocoupler is functioning correctly and affecting switcher. Confirm switcher and flyback is performing within spec.
« Last Edit: July 13, 2018, 02:40:03 am by Shock »
« Reply #34 on: July 13, 2018, 04:17:33 pm »
So I think the 6V never exist. My scope showed a DC-offset which is not real. The waveform below shows the actual measurement
« Last Edit: July 13, 2018, 04:19:17 pm by flattermann1822 »
Offline Shock
« Reply #35 on: July 13, 2018, 08:03:34 pm »
Assumed you put the load back on both outputs for that reading as the 12V is showing pulled down or weak. So the 5V is actually low in that case. Same deal if you want to check everything on the output.
Please also pull and measure the current sense resistor on the primary RP03 - 0.7 ohms 1%, then do the snubber resistor RP01 - 4.7k Ohms 5%? If I have read those correctly, which sounds about right.
Your multimeter might have problems with the first one as it's a low resistance so you could try the ESR tester. If those resistors drift it can cause output issues.
« Last Edit: July 13, 2018, 08:06:00 pm by Shock »
