Update:
voltages at TDA1180:
pin 2: working unit: 4.97V, defective unit:8.98V
pin 5: working unit: 7.40V, defective unit:8.68V
I swapped horizontal final stage darlingtons BU806 from working unit to non-working unit and vice versa.
-> No change. So darlingtons are working both.
Waveform at darlington's collector (line transformer primary and horizontal yoke):
-crt-module-(omni-vision-lp0615e3y)/?action=dlattach;attach=307149;image)
(That's 2 waveforms stacked: 1 high peak per 3 divs period is working unit, 4 smaller peaks per 3 divs period is defective unit).
Then I measured voltages at brightness control potentiometer:
defective unit: -2.2V/-19.5V/-19.5V at left stop, -1.8V/-1.8V/-19.7V at right stop (orange/yellow/green cable)
working unit: -10.9V/-77.5V/-77.5V at left stop, -9.3V/-9.3V/-78.9V at right stop (orange/yellow/green cable)
That correlates to the waveforms, peak amplitude at defective unit is about 1/4 of working unit.
Then I thought the CRT may have a short, so I removed the plug from the tube neck, and after a few minutes, voltages at the brightness pot rised nearly to the normal values, and I was looking at the waveform I checked before: it was slowly transforming from the defective waveform to a waveform nearly the working one.
I set the plug back to the CRT neck, and when I looked at the screen, the picture was back!
What's that?
I tried a little knocking and coolant spray to reproduce the failure, but it wasn't reproducable.
Focus is not as good as the working unit, focus control pot has no effect.
Next, I re-soldered suspective solder joints and washed the pcb with IPA.
After that, I switched the SA on, and the failure was back (no visable picture).
I removed the CRT neck plug and waited a minute or two. The voltages at brightness control stabilizes near normal values, then I put the plug back to the CRT neck, and picture is back!
That's absolutely reproducable!
To get the picture back, you have to remove the plug for some time to build up normal voltages at the line transformer's secondary side, then reconnect the plug!
What the hell could be the root cause for that strange behavior?
