hello, I've seen that when I clone the eeprom as 16bits it remains the same, but if once I read the eeproms clone the original 8bits are different data than the new one, in the original they do not look anything like those read in 16bits, while the new eeprom keeps the same data but inverted.
Are these being read in or out of circuit?
At address A0 in your second image, it looks like the EEPROM suddenly jumped back to the start...
I would set your reader to the slowest speed and try again.
RL86 it is BR93L86 EEPROM from ROHM Semiconductor.
It always work as 16-bit.
What memory you use as replacment (type and manufacturer)?
Regards,
up8051
hello, it's read off-board, the second image is the file that has the emos of yoshimura to load interface, and I do not know how to change the speed of the programmer, I already knew that rl86 is from rohm, I'm using st 93c86wp and also st 93c86 6.
hello, I have seen in a software that I have how to encrypt and decrypt peugeot and citroen files in eeprom, so I see that if the file of the eeprom that I uploaded to the forum can be encrypted, I attach photo.
