Author Topic: (Solved) Need schematics or info for Motorola R-1010A signal generator  (Read 324 times)
Offline CaptDonTopic starter
  • Country: is
This was an Ebay purchase 'as is'. Its main malfunction was a bad LM723CH (TO-5 case) regulator for the +18vdc rail. All other supples are referenced to the +18 so all supplies were about 30% lower than spec. After repairing the power supply board I found 2 of the 4 P.L.L.'s are unlocked. I would like to find a service manual or any info to help me repair the unit. I don't want to just start 'turning things'. Thanks!!
I will also post this in the Ham Radio forum. I have heard this unit was possibly made for Motorola by Boonton or someone else. It is 1MHz to 520MHz in 1KC steps using 6 thumbwheels. I haven't found any useful information online so far.
« Last Edit: January 18, 2024, 05:54:38 pm by CaptDon »
Offline coromonadalix
Re: Need schematics or info for Motorola R-1010A signal generator
« Reply #1 on: January 17, 2024, 03:18:26 pm »
normally  you dont double post  btw
you stay in the repair thread
  • Country: is
« Reply #2 on: January 17, 2024, 03:37:13 pm »
Yup, I don't like cross posting either. I was unsure how many folks really read only one forum? I only read / post to 4 of the forums. I am really reaching out on this R-1010A since although it wears Motorola's name I was advised it was probably made for them by someone else. Local Motorola guys don't seem to recognize the unit.
