Author Topic: Need technical help in changing LCD in farming equipment controller  (Read 2916 times)
Offline markusbTopic starter
Hi
Bought a replacement LCD for our seeder. Same part number as the original, TM0141ADCW.
The one I bought is from Ali, so support is not super easy. Ive already tried for atleast 5h chatting with them and sending dozens of pictures but still not solved.
Problem is Pin numbers are backwards and also the pin functions seems a bit of.
The new LCD also has pin lables thats not there on the mainboard of the seeder, and vice versa.
Original have pins marked  INH, VLC, SL1, SL2, A0 and so on that the new LCD is missing.
The new LCD on the other hand has markings thats not on my board, for example RD, CD, FS, VEE.
Can you guys help me sort this out? How do I wire this LCD to make it work?
I can not find any datasheet for either of the LCDs, only the respective controller ICs on the boards.
New LCD controller IC is - Toshiba T6963CFG
Old LCD controller IC is - RAiO RA8835
Above is the new LCD, below is the original
Pin markings on main board of seeder controller
New LCD and seeder main board.
Also note the LCD is supposed to be turned 180 degrees and that makes LCD pin1 fit mainboard pin22, so its not a direct replacement despite the name being the same. Dont mind the red lines. It was just to show chinese support pin to pin is not possible. They still dont believe me....
Am I on the right track here??
The rest I can not figure out on my own Im afraid.
Offline MarkF
Re: Need technical help in changing LCD in farming equipment controller
« Reply #1 on: March 16, 2024, 11:44:48 am »
Not much help here.
But VEE and VO appear to control the brightness of the display via a pot (R10 on the board if you follow the traces).
Some guesses:
  FS == Font Select
  CE == Chip Enable
  CD == Command/Data
Here's a pinout I found for driving the LCD with an Arduino.
Keep in mind you may not need to connect all the pins.
Also, you the new LCD might not even be compatible.
A quick Google search found some docs for the chips (not the boards) which might be helpful.
 - RAiO RA8835
 - Toshiba T6963CFG
« Last Edit: March 16, 2024, 12:25:58 pm by MarkF »
« Reply #2 on: March 16, 2024, 12:36:01 pm »
Thank You MarkF, this gives me atleast something to work from.
Im also afraid it might not be compatible after all. Might be that no matter how much I try it may never show anything on the new display because of timing in software or whatever.
Ill study what you provided and se how far Im able to make it.
Thank again!
Offline Swake
« Reply #3 on: March 17, 2024, 10:52:47 am »
You might want to try contacting Tianma for a replacement of the LCD or more information about the original screen https://www.tianma.eu/ or in China www.tianma.cn
Mouser seems to be distributing their products.
Searching the web I found someone else with a similar issue saying the TM0141ADCW LCD module itself was a BG128128B from BoLymin. Specsheet attached, it references a 'T6963 controller'.
When it fits stop using the hammer
Offline coromonadalix
« Reply #4 on: March 17, 2024, 01:31:21 pm »
@markusb  you shoud try to post images here on eevblog,  your images link(s) may expire in the future and the forum will loose them in this thread  ...
Online jpanhalt
« Reply #5 on: March 17, 2024, 02:43:34 pm »
The boards appear to be different.  The original is a Samsung controller and the replacement has a Toshiba.  I tried to read the Toshiba number and it looked like T6953CFG, which apparently doesn't exist.  A T6963C does.  Here's its datasheet: https://www.sparkfun.com/datasheets/LCD/Monochrome/Datasheet-T6963C.pdf  That has 2 chip select pins (labeled CD and CE), that  control which half of the screen is being written to.  Your board has two labeled RD and RE, which I assume correspond to CD and CE, respectively.  Aside from that, as you also noticed, there are other discrepancies.
My advice is along the same lines as others have said.  The Ali board might be made to work,* but the best solution is probably to get the original equipment if it is available.
Regards, John
* I just received a different LCD from AliExpress that uses a different controller than yours.  It is advertised as doing parallel plus serial SPI (4-wire) and I2C interfaces.  Guess what?  The board as shipped does not do serial.  I had to modify it by removing several components and adding 10 small (size 603) resistors.  I wouldn't be surprised if that situation is what you will face to make the Ali board work.  At a minimum, it is not plug compatible.  I am waiting for the additional components to arrive before I can find out whether my LCD works at all.
« Reply #6 on: March 17, 2024, 02:49:10 pm »
its the "RES" line on the pcb who bothers me a bit,  all pinout seems standard to a point,  the t6963 supports it
under the blob could be epson, t6963,  ks0066   or others
for sure you need the right controller,  and mostly the 2 chip select as mentioned, the display is driven into 2 sections
« Last Edit: March 17, 2024, 02:57:09 pm by coromonadalix »
Online jpanhalt
« Reply #7 on: March 17, 2024, 02:55:35 pm »
I didn't check that closely.  RES is usually a power on reset rather than going through a  Hitachi type of reset.  I like  ST drivers as they also have an RES pin.  ST also have only one chip select even for a 192 bit wide screen.
Offline amyk
« Reply #8 on: March 18, 2024, 12:35:15 am »
Are you sure the old one has an RA8835? I see what looks like Samsung ICs on it. (S6B20??)
The new one looks like someone just printed "TM0141ADCW" on a label and stuck that on it to scam you --- if you carefully peel that label off, it might have the actual part number underneath. I do see it has the TC6963CFG.
According to the datasheets, a T6963CFG has an entirely different instruction set than RA8835, so you're unlikely to get that to work regardless of pinout.
https://threefivedisplays.com/wp-content/uploads/datasheets/lcd_driver_datasheets/RA8835_REV_3_0_DS.pdf
https://www.alldatasheet.com/datasheet-pdf/pdf/215091/TOSHIBA/T6963CFG.html
« Reply #9 on: March 18, 2024, 01:08:58 am »
picture of the lcd attached  ....
place like this sells it,  but i do see a toshiba driver on it ????
https://www.alcdshopping.com/products/new-compatible-for-lcd-display-module-tm0141adcw
at winstar only theses 2 came out, and they have the toshiba equivalent driver on them  RA6963
https://www.winstar.com.tw/products/graphic-lcd-display-module.html?display_format=128%C3%97128&customfield_3=&customfield_4=&customfield_5=&customfield_6=&customfield_17=&customfield_7=&customfield_8=&customfield_19=&customfield_46=&sort=s
and on Ebay  we do see one  with the RAIO ic ??
https://www.ebay.com/itm/256361714807?
« Last Edit: March 18, 2024, 01:13:14 am by coromonadalix »
« Reply #10 on: March 18, 2024, 07:41:22 am »
Here are the two boards side by side.
RIGHT is old board with RAiO and LEFT is new with Toshiba
This is the place I bought it from, WINNI store on Ali.
https://www.aliexpress.com/item/1005005227821657.html?spm=a2g0o.order_list.order_list_main.65.28a31802qsfiC5
I just tried but no picture showed up. I uploaded, used the button "Insert image" but nothing.
When I upload to imgBB I set it to never delete. Hope its ok.
« Last Edit: March 18, 2024, 10:46:33 am by markusb »
« Reply #11 on: March 18, 2024, 07:47:09 am »
The Samsung you see is just a segment driver. In the post above this I uploaded a pic of both boards so you clearly can se them side by side.
Well if RAiO use another instruction set than Toshiba Im out of luck.
I peeled of the label but nothing was hidden underneath.
Online jpanhalt
« Reply #12 on: March 18, 2024, 10:23:41 am »
Left is old board with RAiO and right is new with Toshiba
Small correction.  Left and right are reversed.  Left is new board  with Toshiba and cob's.  That is obvious and doesn't cause more than a second of confusion.
The problem of posting images inline is inherent in this forum.  That insert in line button does not work.    Just put image tags where you want the image to be.
[img] [/img] Upload the image as you did. Then post, go to modify, copy the url for the uploaded image, paste that between the tags, and save.  It's a pain, but it has been that way for a very long time.
I prefer images on this site as off site postings can be difficult to access.  Moreover the site you used gave a popup with unrelated, apparently sexually related material about being a champion in the bedroom.
I did not check the instructions as the other member did.  That's almost certainly a killer.  J
« Last Edit: March 18, 2024, 10:29:10 am by jpanhalt »
« Reply #13 on: March 18, 2024, 10:50:45 am »
Thanks for noticing my error. Fixed it in previous post.
I understand. I use uBlock and other adblocker so I never see suspicious ads. Ill try posting to the forum as you suggested next time.
Offline djrm
« Reply #14 on: March 18, 2024, 01:02:17 pm »
I have use the T6369 controllers a few times.
CD (command/Data) is sometimes referred to as A0 (address 0)
CE (chip enable) is probably synonymous with CS (chip select)
The reset line is active low, it needs to be high for the controller to run, it should be toggled by software but could just be a static line at Vcc.
FG probably means Frame ground, i.e. the chassis / metalwork of the display
FS (font select) selects one of two inbuilt fonts, usually grounded.
The data sheet for the RA8855 looks as if it is a clone of the T6369
I'd say that if you get the connections sorted then there is a good chance it will work for you.
hth David.
Offline amyk
« Reply #15 on: March 19, 2024, 03:36:48 am »
As the pictures above show, we're talking about a T6963CFG and an RA8835.
Sorry, but I'd say the OP has been scammed. The two controllers have completely different instruction sets and the alleged "TM014A1ADCW" is actually not made by Tianma(天马) but 深圳市信盛液晶有限公司.
RA8835 appears to have a similar instruction set to Epson SED1335, S1D13305, S1D1370x, etc. Thus finding a display of the same dimensions with one of those controllers may be better.
(What's wrong with the original one? Couldn't fix it?)
« Reply #16 on: March 19, 2024, 06:34:52 pm »
For the moment Ive given up on this. Boss wanted me to put it back together with the original LCD so he can use the seeder soon.
The chinese told me they will refund the money so Im waiting on that.
Dead pixel columns but still pretty usable for those who know how its supposed to look.
hth David.
Thanks for the info!
Some people say the protocol is different, some say it might work. At the moment I put it back the way it was. Maybe I take a look at it again after the seeding season.
Online jpanhalt
« Reply #17 on: March 19, 2024, 07:17:41 pm »
That's good news about the refund  AliExpress seems to keep its sellers somewhat honest.
I was worried when your planting season began.  Ours is not quite, but it will be soon (Northern Ohio, about 41.2°N).  I am surrounded by  corn, soybeans, and pigs.  My closest neighbor has about 600 acres in soybeans just for his pigs (plus plenty of field corn).
That exact replacement shown earlier was reasonably priced, come the right time.
John
Offline amyk
« Reply #18 on: March 20, 2024, 12:14:37 am »
Likely to just be a bad connection; opening it up and cleaning the zebra strips may fix it. Column drivers rarely fail on LCDs of this type.
« Reply #19 on: March 20, 2024, 09:38:08 am »
I did, two times but made no difference. Might still be a problem with the zebra strips or the drivers.
Online jpanhalt
« Reply #20 on: March 20, 2024, 09:50:36 am »
Some people have had good luck disassembling, cleaning, and rebuilding LCD zebra strips.  My experience has not been as good.  I suspect practice helps, but now does not seem like a good time to try it.
