Author Topic: Need to identify degraded computer monitor screen membrane  (Read 684 times)
Offline Tim88Topic starter
« on: August 26, 2024, 08:16:31 pm »
This monitor got very hot and the heat evidently degraded this reflective coating/sheet. Not exactly sure what you call it and hopefully a guy can get some replacement? You are looking at what is left after removing 3 plastic sheets and the led screen. Remaining (the pic) is a piece of glass with the degraded white stuff underneath. Looks like it is gonna be a mess so haven't taken it any further till I know what is what.
Thanks!
Offline amyk
Re: Need to identify degraded computer monitor screen membrane
« Reply #1 on: August 27, 2024, 02:26:16 am »
What type of monitor is this? LCD or OLED?
« Reply #2 on: August 27, 2024, 03:55:51 am »
It is a LCD.
Offline coromonadalix
« Reply #3 on: August 27, 2024, 08:07:29 am »
would help  if any model   print  text    where it com from  .... brand  etc ...
« Reply #4 on: August 27, 2024, 02:12:48 pm »
Sorry, it's an Acer Predator XB1 XB321HK. I thought all monitors had the same screen components. :-//
Offline amyk
« Reply #5 on: August 29, 2024, 02:30:24 am »
Is this between the LCD panel and the side you look at, or between the panel and the backlight?
« Reply #6 on: August 29, 2024, 10:24:02 pm »
You are looking at what is left after removing the LCD panel and 3 layers of plastic film. It is a sheet of glass with something whitish behind it.
Offline MAS3
« Reply #7 on: August 29, 2024, 10:41:56 pm »
That would be the diffuser , meant to evenly distribute the backlight.
The following users thanked this post: amyk
Offline Whales
    • Halestrom
« Reply #8 on: August 29, 2024, 10:44:03 pm »
Every monitor has a different stackup of layers made by different companies.  Best you can probably do is pull apart some broken monitors of the same size, try switching the parts and see how it looks.
Work somewhere very clean (ideally under a flow hood but few have those) otherwise you will end up with annoying specs of dirt and hair visible in the screen.
Offline amyk
« Reply #9 on: August 30, 2024, 02:16:13 am »
Look for diffuser sheets. They're widely available online.
« Reply #10 on: August 30, 2024, 02:23:54 pm »
Ok, did a little looking on the diffusion sheets and I believe those are the 3 sheets I removed just under the LCD panel? Found a couple pics and isn't what I need is the white reflection film?
