I found a parts list for a SONY DA-792:
https://remont-aud.net/dump/lcd_dvd_tv/sony/sony_da_792/318-1-0-7022The list includes MST712CX-LF and EN25F10.
The buck regulator is a TD1410.
TD1410, Techcode Semiconductor, PWM Buck DC/DC Converter, 2A, 380Khz, 20V, SOIC-8:
http://dalincom.ru/datasheet/TD1410.pdfhttp://www.techcodesemi.com/datasheet/TD1410.pdfThe pinout is a match. However, the feedback voltage is 1.222V, which means that …
Vout = 1.222 x 1.24 = 1.52V
The TD1410 requires an external Schottky diode, as does the video intercom PCB. If we could confirm that the Vcore requirement for the MST712CX SoC is 1.5V, then I think the TD1410 would be a suitable replacement.
Edit:
This IC appears to be an equivalent.
BM1410A, Bookly, step-down DC-DC converter, 2.2A, 380kHz, 5V - 23Vin, SOP-8:
http://www.bookly.com/images/BM1410A.pdfIt is pin compatible with ACT4060/ TD1410 / MP1410.
So it would seem that there are at least 4 possible substitutes.
Edit #2:
MP1410, Monolithic Power, step down switch mode regulator, 2A, 4.75V - 15Vin, 380kHz, SOIC-8:
file.yizimg.com/332467/2009080605462983.pdfThe ACT4060 has a slightly higher FB voltage (1.293), so Vout = 1.293 x 1.24 = 1.60V
ACT4060, Active Semi, step-down DC/DC converter, 2A, 420kHz, 4.5V - 20Vin, SOP-8:
file.yizimg.com/332467/2009072110594237.pdfYet another substitute (FB = 1.222V):
FP6182, Feeling Technology, 2A, 23V, 380KHz Step-Down Converter, SOP-8:
http://www.feeling-tech.com.tw/km-master/ezcatfiles/cust/img/img/24/fp6182v061-g1.pdf
