Author Topic: Needing help identifying a couple of components  (Read 1639 times)
Offline jamiecTopic starter
« on: July 27, 2016, 09:18:14 pm »
Hey, Thanks for looking at my post. I am looking to identify 2 components on a PCB i am repairing.
The board is used for heart rate so i am assuming one is a sender and one is a receiver for the heart rate.
Thanks in advance for any help.  :)
Jamie
Offline Gyro
Re: Needing help identifying a couple of components
« Reply #1 on: July 27, 2016, 09:30:31 pm »
If it's from a pulse oximeter (heart rate plus O2 saturation) then the top picture is a dual LED, one Red and one IR die. The bottom one is a photodiode.
Best Regards, Chris
The following users thanked this post: jamiec
« Reply #2 on: July 27, 2016, 09:33:27 pm »
Thats fantastic, Thank you very much.
I have just checked the top chip with my Diode Tester and it does emit red light.
Thank you very much for your help.
Jamie
Offline Gyro
« Reply #3 on: July 27, 2016, 09:38:20 pm »
You're welcome.  :)
Chris
Best Regards, Chris
Offline StillTrying
  • Country: Broken Britain
« Reply #4 on: July 27, 2016, 10:03:38 pm »
You should be able to see the IR bit by viewing it through a phone camera!
Offline noidea
« Reply #5 on: July 28, 2016, 03:42:48 pm »
Just don't to use an iphone rear camera as they have an IR blocking filter in them
