First time posting here so forgive potential submission errors (I will endeavor to fix any missing required information as I know about it). I have a Phillips AV1002 amplifier, and am incapable of finding a service manual for making a repair. The issue lies in the input sub-board, two resistors have burned completely out, to the point that I cannot read their values, and a trace on the backside of the board itself appears to have exploded or burnt out as well. I am skilled with general electronics repair, and can figure out how to best replace and repair the issues, but am stumped as to what value resistors I need to replace.
If anyone knows where I can look to find a service manual, or has one, or can send me some photos of the board in question, it would be most appreciated. I've done as much digging as I can think to do, none of my usual sources for service/repair manuals have yielded any fruit. I've done about as much investigation of the board itself, and sadly the components don't seem to be mirrored in any capacity so I cannot figure how to infer the values based on the surrounding circuit itself.
The resistors in question are marked as "RED1" and "RED2" on the board in silkscreen, and aside from one other bulged capacitor nothing else has tested or appeared damaged so far. The board itself is marked as "PE01", with what appears to be a serial number of "YK055J163-3".
Attached to this post are photos of the board in question, I had to turn the compression up some to get past the attach size limitations but I can send higher-quality original photos if necessary.
Thank you for any and all help, it is much appreciated.
Regards
