A long time ago I made a kit from an electronics magazine, of which I attach the schematic and components. I detect the 311Volt from the rectifier and the 5 Volt on pin 8 of the integrated UC.3843. I am unable to supply power to both the high voltage, through the L3 winding of the transformer T1, and to the fan and LEDs that are on the L4 winding. I tried to remove C10 and DS9 by putting a 10 MΩ resistor and in this case the fan turns, the LED lights up and I have 16.9 Volts on pin 7, but I don't have high voltage on the needles. If I reset everything as it was originally (removing the 10 MΩ resistor) the fan stops turning and the LED does not turn on either (on the fan terminal I measure 0,9 Volt !!). What could I do to make IC1 and MFT1 deliver a little more current sufficient to make both parties work? Thanks for help....
