Don't!
Those supplies from Acopian are factory-wired for either positive or negative output voltage: the "P" prefix denotes positive.
See Acopian link in my reply below.
They supply either the module, or the module mounted in a rack-mount housing with meters.
At the beginning of the instructions, note "The high voltage output return, signal ground, programming ground and case ground are common and internally connected."
