Author Topic: Laptop Toshiba Dynabook Satellite Pro C50-H-101 does not power up  (Read 1335 times)
Offline sdancer75Topic starter
  • Country: gr
I found that motherboard's +1.2v (memory power rail) and +1v (cpu power rail) are missing. An smd capacitor around M2940A IC (powers cpu and memory) and maybe the power regulator IC itself are shorted. +3v and +5v are ok and bios VIn is also ok.
I am thinking to replace the both IC and capacitors around them, but I don't know the values of them.
So, Is there any schematic of the motherboard and/or a datasheet for the M2940A IC?
Is there anyway to know that cpu itself is not shorted?
« Last Edit: August 22, 2023, 10:17:42 pm by sdancer75 »
Offline fmashockie
Re: Laptop Toshiba Dynabook Satellite Pro C50-H-101 does not power up
« Reply #1 on: August 20, 2023, 08:22:58 pm »
Here's the datasheet for LM2940 https://www.ti.com/lit/ds/symlink/lm2940-n.pdf?ts=1692534539894&ref_url=https%253A%252F%252Fwww.google.com%252F
But just because you have a short on this power rail, does not mean the problem is with voltage regulator.  It could be any component on that power rail causing the short.  You could use a multimeter with high precision (3 or more sig figs like a benchtop multimeter) to narrow down the location of the short on the board.
The following users thanked this post: sdancer75
  • Country: gr
« Reply #2 on: August 21, 2023, 07:19:02 am »
Thank you for your reply.
The datasheet refers to another component. The actual component looks like this
the SMD capacitors around the IC are definitely shorted, so I suspect IC itself is also shorted. Testing pads just before MP2940A IC are getting +5V and +3V.
« Last Edit: August 22, 2023, 07:55:59 am by sdancer75 »
Offline fmashockie
« Reply #3 on: August 21, 2023, 03:40:20 pm »
Sorry about that.  It appears to be an MPS (monolothic power systems) device.  I cannot find anything on it.  Searching their website doesn't yield any results.  The closest thing I could find is the MP2930 (link here https://www.monolithicpower.com/en/mp2930.html ).  It seems like it is an obsolete device possibly.  Might be worth reaching out to MPS directly for a datasheet if you need it, or a suitable replacement.
Offline fzabkar
« Reply #4 on: August 21, 2023, 09:59:50 pm »
Could the IC be a custom part? Could 465899 be a Toshiba part number? What are the date codes on the other ICs?
Maybe you could search for off-the-shelf ICs of that era at the Wayback Machine:
https://web.archive.org/web/20230000000000*/https://www.monolithicpower.com/
I suspect that the actual part number may be MPM2940A.
  • Country: gr
« Reply #5 on: August 22, 2023, 07:44:10 am »
Thanks for the reply. I found some schematic block examples from monolithic that denotes the part as M2940A. Does not actually denotes the pinout but rather a draft block connection diagram.
The actual photos of the component are attached in this post.
« Last Edit: August 22, 2023, 08:01:08 am by sdancer75 »
Offline fzabkar
« Reply #6 on: August 22, 2023, 06:57:29 pm »
The mystery part must be MP2940A.
Attached is the marking code for an MP86905 for comparison purposes.
