Author Topic: Netatmo thermostat power supply  (Read 420 times)
Offline yo3gtsTopic starter
« on: August 29, 2023, 05:26:53 pm »
Hello, I have a power supply from Netatmo thermostat and I found the driver burnt and I don't know what integrated it is, it says .1UAF
The final transistor is 13003 and it is ok, the capacitors are ok, only the 3.9R resistance is burnt.
I have the request, maybe someone knows what SMPS with 6 pins is.
Thank you
