Hi, my Netgear WNDR4500 worked fine until I had it off for about 2 weeks. When I plugged it back in it didn't work anymore, there isn't even any lights flickering.
I changed the power supply, so that's not the problem.
Inside the router there is a regular clicking sound with about 1.3Hz. I believe it is coming from the round green component (I believe a self resetting fuse). I encircled it pink.
This part also gets really hot after 20s - I could smell something making me worried before opening. Can't see any damage, the big capacitors seem ok and hold some charge tested with a multimeter. Also the 2 flat fuses X250F right behind the power switch have continuity.
Any ideas what happened? I'm mostly curious and more than fixing it I'd like to know what is wrong and happened - so even "destructive" experiments would be ok.
