Author Topic: NEVA 5225 Power Supply  (Read 1785 times)
Offline 09d08Topic starter
« on: November 24, 2018, 10:52:35 am »
I'm trying to fix a rather old power supply. I saw two burned components on one of the two boards, one of them is definitely a resistor but I have no idea about the other axial metal one. The burned axial part is connected to the base and the collector of a BC547. I have just started to draw a schematic of the board so I'll attach the partial schematic and the pictures of the burned components. I hope someone has an idea what that axial one next to the resistor might be.
Thanks in advance
Offline coromonadalix
Re: NEVA 5225 Power Supply
« Reply #1 on: November 24, 2018, 02:18:24 pm »
maybe a zenner diode with the orange gold color on the photo ???  would fit the size of the part ?
« Reply #2 on: November 24, 2018, 05:51:30 pm »
It's larger than a regular zener diode and every diode on the board. I believe it's a metal axial capacitor but I'm not very sure.
Offline madires
  • A qualified hobbyist ;)
« Reply #3 on: November 24, 2018, 06:13:30 pm »
Yep, a capacitor might be possible. BTW, I'd also check the Philips electrolytic caps since they are known to go bad.
« Reply #4 on: November 24, 2018, 06:20:39 pm »
search for the : GPD3303SM  service manual  there is a similar circuit,  mosfet driven serial power supply, or any similar design
this one seems similar in some ways : http://powersupply33.com/transformerless-power-supply-fet.html
I would say  complete your schematic ... it would help to understand the circuit more ?
« Last Edit: November 24, 2018, 06:23:21 pm by coromonadalix »
The following users thanked this post: 09d08
« Reply #5 on: November 24, 2018, 06:55:47 pm »
Their values seemed normal but I'll also check their ESR.
They indeed seem similar, I'll try to map the feedback portion and other parts involving the tl074.
