Author Topic: new batteries drain fast  (Read 1133 times)
Offline AnnavaTopic starter
  • Country: hk
« on: January 17, 2023, 09:10:19 am »
The aa and aaa batteries in the kits show as fully charged in my ebl charger, but the batteries die within minutes when installed in a device. this is not at all how my other older ebl batteries last- they power the same device for around one week before needing to be recharged.
returning things wastes my time. If there is any ideas for this issue? thanks
video here, 4 old batteries work well, but new one drain fast
https://www.pinterest.com/pin/1030409589723155665/
Offline abdulbadii
Re: new batteries drain fast
« Reply #1 on: January 17, 2023, 12:37:20 pm »
none can read your mind
outright useless seek solution or simply non sense with no info,
what is ebl ?
what is aa aaa, is it rechargeable battery of AA or AAA size ?
what is the electrochemistry compounds or type of this rechargeable battery Zn-MnO2, rechargeable Ni-Zn b, alkaline: RAM, NiCd, NiMh, Li-ion or Li-Po ?
what is this rechargeable battery capacity, how many cell in each battery of that type
how many voltage read in charger, and reread how many if represent with a correct battery or diode; to distinguish linear or nonlinear output by the charger
Offline Swake
« Reply #2 on: January 17, 2023, 04:25:11 pm »
The linked video answers a lot of questions already.
I believe your charger is EBL model RM-76 8-Bay. This one charges NiMH batteries only. Can you confirm the batteries are NiMH too?
The charger seems to indicate that the new battery is fully charged. Don't trust that indication al too much, it is just what it is, an indication. It probably is based on the voltage of the battery not on its capacity. Some will argue that the voltage is a function of the capacity and that is true but these are brand new batteries and your charger might be fooled with this.
Try to charge the batteries first and retest. For AA 1,5h minimum, 3 hours if you put 8 batteries in the charger.
When it fits stop using the hammer
Online Grandchuck
« Reply #3 on: January 17, 2023, 04:25:30 pm »
It seems that you should return them.
  • Country: hk
« Reply #4 on: January 18, 2023, 07:00:11 am »
what is ebl ?
thank you for your concern.
I can't say much about this ebl brand, they sell battery and charger.
I read the forum rules and I can't put a link to the battery I purchased directly to you, or the platform might kick me out.
rechargeable aa ni-mh battery, 2800mah.
test my battery voltage atound 0.5V~0.8V
  • Country: hk
« Reply #5 on: January 18, 2023, 07:05:37 am »
yeah, the charger is EBL RM78 16bays, my battery is ni-mh battery 2800mah,1.2V. Thanks for your advice, I've already charged them, but seems nothing change.
  • Country: hk
« Reply #6 on: January 18, 2023, 07:09:03 am »
I am also contact with eblofficial sites customers service team. They will give me feedback after got reply from their engineer.
If no way finally, I'll have to send them back.
  • Country: hk
« Reply #7 on: February 22, 2023, 07:40:47 am »
hi all, back here and update. my issue is solved. all batteries work well now. eblofficial posted a blog on how to solve this issue. In one words, should active batteries, charging and discharging several times, note that the correct charger--discharge the battery at low current.
If any guys have the same issue, highly recommend the blog-- Why Do Fully Charged Batteries Die Quickly? Reason And Solution.eblofficial.com. Hope it helps you.
« Last Edit: February 22, 2023, 07:45:55 am by Annava »
Offline shakalnokturn
« Reply #8 on: February 22, 2023, 02:57:46 pm »
That makes it sound as if they were selling you used batteries severely hit by the memory effect.
Have you tried measuring the capacity during discharge before and after reconditioning them with a few cycles?
