Hello fellow EEVers,
I have recently received my CMU200, what I think a bargain (because of a non working screen), initially passes all tests while using an external monitor.
After studying the various threads, I was hoping that the screen problem was due to failed CCFCL or inverter.
I'm happy to say that it appears that is the case and a simple fix of the inverter or lamp is required as I can see the LCD working when illuminated by a torch. I haven't opened it yet as I'm waiting for replacement SSD to swap the HD at the same time as fixing the screen driver (hopefully a 30p SMD fuse :-) )
My unit is fitted with B12 OCXO and additional generator and trying to work out what the rest are from the identity.dat file.
The unit has fairly old 4.35 firmware and I'm wanting to know which base firmware best to update with and which options to enable, but waiting until I've backed up the existing HD and replaced with a 32gb SSD.
Interestingly Demo pack elapse time is only 4,200hrs where as many of the others I have seen on line have +30,000hrs. Does this mean my unit has had low useage?
Photos attached.
GENERAL INFORMATION
Serial number: 10XXXX/002
CPU and memory:
CPU (FMR) FMR6
Memory 256 MB
BSW/FSW V4.35
Statistics data:
Firmware versions:
RXTX_1 CP-SW 08.50, 2006-05-02
Available options:
rxtx1 V8.50 02.05.06
PMGR_RX_DSP_1
PMGR_TX_DSP_1
AUXTX_1
CMU-B21Var14
CMU-B56Var14
CMU-B54Var14
COPROC
COPROC_FULL 3.04
CMU-B83 V2.84q (Var. 12)
CMU-B88 Rev. 0
CMU-B21
2G_Signalling
CMU-B66 included in B68
CMU-B76 included in B78
DIG
DIG_HWC HWC: 4
DIG_FM
ADC 1
WDDC400
CMU-U65
AUC 1
OCXO 2
NETCLK 1
NETCLK 2
REF_EEP
RXTX1_EEP
CORR1_EEP
DIG_EEP
AUC1_EEP
ADC1_EEP
AUXTX_EEP
RXTX1_DG DG: 13
RXIF3_1
CMU-B11/B12 B12
Harddisk
PCMCIA
CPU Intel Pentium III
CRTU-B1/B2 B2
FE (1100.3120.02)
CMUDrv
CMU-B95
CMU
K21
K22
K23
K24
K27
K28
K29
K42
K43
K59
K61
K62
K63
K65
K66
K67
K68
K69
K83
K84
K85
K86
K88
K92
Audio
RF
GSM 850 MS
GSM 900 MS
GSM 1800 MS
GSM 1900 MS
IS136 800 MS
IS136 1900 MS
WCDMA Signalling B
WCDMA Signalling B
WCDMA Signalling B
WCDMA Signalling B
WCDMA HSUPA
WCDMA HSDPA 10Mbps
WCDMA Signalling B
WCDMA Signalling B
WCDMA Signalling B
WCDMA HSDPA 3.6
WCDMA TX Tests
WCDMA DL Generator
WCDMA Signalling B
WCDMA Signalling B
WCDMA Signalling B
WCDMA Application
WCDMA WB AMR
cdma2000 450 MS
cdma2000 800 MS
cdma2000 1900 MS
cdma2000 2200 MS
1xEV-DO
EVDO_DSP
A great forum, I hope you don't mind a 'beginner' picking your brains.
Dek
