Author Topic: Nikon d40 repair  (Read 7235 times)
Offline Yannique1Topic starter
Nikon d40 repair
« on: November 15, 2014, 10:17:29 pm »
Hi everybody, I've been a follower of the EEVBlog on Youtube for a long time, but now I need some help since I'm not an expert, just someone who tries to tag along....
I have a Nikon d40 DSLR as a backup camera. A few weeks ago the autofocus gave out, it was the motor. I replaced it together with the LCD protection glass and everything went well. Few days ago the d40 died on me all of a sudden, nothing, njet...
Today I d/l the Nikon repair manual, took the shields off, took out the main pcb and something made a rattling noise there when I shook the board.
At first I thought it was the SD card slot, but it was the component next to it. I desoldered it to make sure and it is rattling indeed.
Problem is that I have totally no idea what it is, and I think people do know just by taking a look at it. So I'll post some pictures of the thing and if you guys can tell me what it is, and what I can replace it with, I would be very grateful!
Thank you!
Offline Deamiter
Re: Nikon d40 repair
« Reply #1 on: November 16, 2014, 04:00:39 am »
I think you're going to want to put that back on. My guess is that it's the orientation sensor -- a metal ball inside there shorts contacts to tell the camera which way is down.
I did a little searching, and while I couldn't find the part or an image of the part, I did find this post from dpreview where someone else has the same hypothesis about that rattling as I did:
http://www.dpreview.com/forums/post/23624782
Note that I can't identify the part myself, and I don't have experience with the D40. I'm just guessing, but after finding the same guess posted on dpreview, I thought it'd be worth responding.
« Reply #2 on: November 16, 2014, 04:55:31 am »
Thank you very much, I was thinking something along those lines...I can just solder it back on. Problem now is that the reason for the camera being death is gone :(
Offline TiN
  • Country: ua
    • xDevs.com
« Reply #3 on: November 16, 2014, 02:03:13 pm »
Yes, that's mechanical orientation sensor :)
Offline Teemo
  • Country: ee
« Reply #4 on: November 16, 2014, 04:58:40 pm »
In case of dead camera first things to look is power ON switch and battery related issues, maybe stuck shutter button. Do the camera shows any signs of life, blinks the led when inserting memory card? Usually the fault is much simpler than at first guessed. :)
Offline sportq
« Reply #5 on: November 17, 2014, 09:01:46 am »
Odd, the D40 doesn't have an autofocus motor, they only autofocus with DX lens which have the motor in the lens body.
Peter
Tac Eht Xilef
  • Guest
« Reply #6 on: November 17, 2014, 12:32:55 pm »
Peter
Yeah, I'd been wondering about that myself...
Offline lowimpedance
  • Watts in an ohm?
« Reply #7 on: November 18, 2014, 02:00:05 am »
Peter
Indeed it does. I have a d40 that regularly has issues with the auto focus not working, just a faint clicking sound and no focusing action!.
The temporary fix is to unlock the lens and rotate as if to remove then rotate back to lock. My assumption is the contacts between the body and lens are not the best and maybe some oxide build up is preventing a good electrical contact, until 'wiped' by my action of rotating the lens
which never fails to restore the auto focus function.
(note that the auto focus stops working if the camera is not used for sometime, but continues with no issues after the temporary fix until put away again!).
Offline sportq
« Reply #8 on: November 18, 2014, 10:01:11 am »
How does that prove there's an autofocus motor in the body? (there definitely isn't).
Peter
  • Watts in an ohm?
« Reply #9 on: November 18, 2014, 11:15:52 am »
Peter
Oh , what i meant was you were correct that it " indeed does not" have a motor, and its the lens. Pardon me, I should have been clearer !!.
As for the auto focus problem, I wonder if its common on others d40's or other models that have no motors.
« Last Edit: November 18, 2014, 11:17:23 am by lowimpedance »
Tac Eht Xilef
  • Guest
« Reply #10 on: November 19, 2014, 12:18:00 am »
Mine acts much the same as you describe, but only with the kit 18-55. Since that one has basically taken a beating as my go-everywhere field trip lens, it started playing up at the same time the zoom started binding and getting all grind-y, and sometimes it can also be made good by switching to MF and back, I figured it was the lens mechanism succumbing to 6 or 7 years of rain/sand/salt/dust/freezing/baking rather than the contacts or body.
  • Watts in an ohm?
« Reply #11 on: November 19, 2014, 01:21:39 am »
Same lens on mine. But mine has not had any rough treatment as such, so I am only guessing that its the contacts.
So long as its easily rectified (for a time!) I have not delved any deeper.
