Author Topic: Nichicon Electrolytic Capacitors leaking - common problem? ( Rifa X and Y also)  (Read 11799 times)
Offline Gyro
Hi, thanks for the information. Are the failed RIFA capacitors all PME 271 type ?
Yes, those are the ones.
Best Regards, Chris
Online tggzzz
Don't forget to look inside the mains power socket. Sometimes there is a filter inside it, and guess what... !
You mean RIFA filled pipe bomb :(
Offline factory
Hi, thanks for the information. Are the failed RIFA capacitors all PME 271 type ?  Most of the PME271 I have, even the new old stock, NOS, have cracks. I also have RIFA PMZ2050M NOS but without cracks. Regards.
RIFA/Kemet (whatever they call themselves in the future) PME, PMZ, PMR, PZB & PMP are all metallized paper types, throw them away unless you like the random RIFA madness failures, best place for paper based capacitors, is in history books and/or a museum.
Offline CZAK_SHADETEK
Im in the middle of recapping the P/S on an HP 8080A. Found all the rifas but still something wrong... test pins at the p/s are all reading correctly (A = 11.8v,  B = 5v ~ 1.8v saw, etc.) but nothing at the multicon. Hoping someone has a schematic or a link.
THx!
Online tggzzz
Don't know what you mean by "multicon".
Don't forget the ripple (AC) voltage is as important as the mean (DC) voltage, and is a better indicator of whether the bulk capacitors have dried out.
Offline Zenith
THx!
Almost all HP manuals are easily available on the WWW. I'd be surprised if this wasn't.
If you are very unlucky it will be a PSU HP bought in from another company, and the schematic isn't available.
Offline factory
The manual with circuit diagrams for the HP 8080A is on ElektroTanya, for some unknown reason keysight haven't got the pdf anymore, but do have some for the plug-in modules; https://elektrotanya.com/hp_agilent-technologies_8080a_frequency_generator.pdf/download.html#dl
Seems to be a switching based supply, with linear regulators for each secondary outputs, probably best to start a new thread for the repair.
« Last Edit: April 26, 2024, 05:29:26 pm by factory »
