Author Topic: Nikon MH-23 quick charger doesn't work.  (Read 1940 times)
Offline GerardoTopic starter
  • Country: mx
« on: March 19, 2016, 10:38:09 pm »
Hello,
I have a Nikon MH-23 quick charger. Some months ago, it suddenly stop charging the battery. Even the LED indicator doesn't turn on. I checked the fuse and it's ok. The voltage after the diode bridge is correct. The control IC also has voltage to feed it (5Vdc). In the output of the the flyback secondary side the voltage is also present (8Vdc). I tested the LED individually and it's fine, in fact I notice that the control IC don't send voltage to it.
Apparently neither component looks like broken or burned. Ofcourse, I know it doesn't assure the correct operation of each component. I believe maybe some protection is already activated. Some one have an idea of what's happening or how I must proceed to check it?.
Thanks.
Online IanB
Re: Nikon MH-23 quick charger doesn't work.
« Reply #1 on: March 19, 2016, 11:02:37 pm »
Have you tested the battery with a different charger? It could be the battery that is not working rather than the charger.
If the battery has failed the charger may refuse to charge it.
