Author Topic: Repair of $150k Phantom Flex 4k camera - advanced soldering  (Read 4707 times)
Offline rx8pilotTopic starter
Re: Repair of $150k Phantom Flex 4k camera - advanced soldering
« Reply #25 on: September 16, 2019, 04:31:18 am »
This project saw some success today! I will say it was the most anxious I have ever been soldering anything. The cost of failure was rather extreme by my standards.
In the end, I elected to design and machine two special fixtures that would hold the PCB, provide thermal protection for the existing connectors, and provide a way to apply heat safely. Certainly the first time I have ever machined parts to solder a single connector. Lots of consideration and half a day at the CNC - it was game time.
I put all the parts in the convection batch oven and pre-heated at 100C for about an hour followed by 150C for 5min and 200C for 3min. At that point, I transferred the fixture to the bench where I had a special holder ready and 2 hot-air systems. One hot air was setup to heat from the bottom of the PCB, the other was handheld and focused on the work area. All was being watched with a microscope so I could see the moment the solder melted. Lots and lots of tacky flux was pumped in and I kept some motion on the hot air nozzle to avoid melting the connector.
Initially, I was planning to remove the connector, clean the pad/pins, stencil paste, and re-flow. Once the original solder flowed, I decided not to remove the connector and see how it looked. With all the flux, the solder wicked nicely on the connector pins leaving a nice fillet and a shiny finish. At that point, I decided not to remove it and examine the result more closely. After a clean-up and examination under the microscope - all pins flowed and looked great.
The fixture protected all the other connectors well and the end result looks like a brand new board. What a challenge. It was fun.
« Last Edit: September 16, 2019, 04:34:51 am by rx8pilot »
The following users thanked this post: SilverSolder, tooki, ogden, Samogon
Offline Psi
« Reply #26 on: September 16, 2019, 04:35:53 am »
Out of interest, are you trying to fix for someone else or do you get to keep it :D
« Reply #27 on: September 16, 2019, 04:46:37 am »
I definitely do not get to keep it. The owner is paying for the effort so once it is back together and tested, it will go away. I should say that even after this part was repaired, the project is not out of the woods yet. The re-assembly is rather delicate with the image sensor being particularly so. I would estimate that the sensor PCB is worth $60-$80k or so.
Gotta be careful.
Typet purly on my fone.
« Reply #28 on: September 18, 2019, 12:37:30 am »
The camera is back together and appears to be working. Lots of tests need to be done, but this is solid progress.
The following users thanked this post: Psi, thm_w, ogden
Offline Bobertsawesome
« Reply #29 on: September 19, 2019, 08:40:42 pm »
I would be shitting myself having to work on that thing being the cost. Good job on getting it running.
Just a hobbyist and evolving voltnut
« Reply #30 on: September 19, 2019, 08:49:09 pm »
I am not saying that did not happen......... :-DD :-DD :-DD :-DD
Offline Psi
« Reply #31 on: September 19, 2019, 11:42:20 pm »
I hope you billed them a sizable amount. The repair cost should carry a premium for something so expensive, even if the actual repair process wasn't that hard.
Lots of extra care and attention had to be taken and extra stress etc..
« Last Edit: September 19, 2019, 11:44:46 pm by Psi »
Offline Dubbie
« Reply #32 on: September 19, 2019, 11:59:36 pm »
Nice work rx8!
Love to see some custom made tooling!
Offline Mr. Scram
  • Display aficionado
« Reply #33 on: September 20, 2019, 02:01:33 am »
Except that it was hard. Milling custom brackets on a CNC machine that you happened to have into your garage isn't everyday fare. Lots of high dollar investments and a highly varied skill set are required.
« Reply #34 on: September 20, 2019, 04:09:16 pm »
The agreement was fair, I think. Essentially I based the fee off of a bench technician and machine shop rate to cover the time and materials needed to attempt the repair. If the repair was not possible, that would be all I charge. If I fixed it, however, the rate tripled to cover the value of having a unique setup and skillset to make this happen.
That arrangement was great for me and the owner of the camera.
Offline Psi
« Reply #35 on: September 21, 2019, 09:51:31 am »
It sounded a lot more like a very careful and time consuming repair job than a hard repair job.
« Reply #36 on: September 21, 2019, 05:01:16 pm »
Yes, exactly. It was all physical/visible failures so diagnostics were not a challenge. Just look through a microscope and that is it. This was all about being slow and methodical in the process of figuring out how to repair it.
The previous Phantoms I have worked on needed component level diagnostics and repairs. SDI drivers/receivers and numerous components related to power management and PDN.
Offline TiN
  • Country: ua
    • xDevs.com
« Reply #37 on: September 21, 2019, 05:20:40 pm »
Thanks to you and to owner for sharing the story.  :-+
« Reply #38 on: September 21, 2019, 05:25:14 pm »
I recorded video of most everything and trying to cut a YouTube video for those that are curious how it all went.
The following users thanked this post: Psi, TiN, sokoloff, cgroen
Offline richnormand
« Reply #39 on: September 21, 2019, 08:32:16 pm »
Excellent work there, interesting post indeed.
I have come across similar issues with bad geometries for the soldering iron or using hot air pencils that could damage other stuff around.
I rigged my stereo microscope with a micrometer x-y stage and z adjust to get a stable fix on the area. I keep around an old Pace SensaTemp PS90 soldering iron for these jobs.
This uses solid 1/8" diag (or so) tips that are held with a side set-screw. It is then easy to machine a soldering tip out of a solid copper rod with all the right bends, size, diameter and curves to reach the area to be repaired.
Flux and pre-tin the resultant tip, check temperature and apply to spot to be done. Used aluminium foils with one adhesive side and kapton tape on surrounding devices.
I have done this 8 or 9 times over the years with very good success and no collateral damage on LN2 IR detectors, EDX and microwave stuff.
« Last Edit: September 21, 2019, 08:35:41 pm by richnormand »
Repair, Renew, Reuse, Recycle, Rebuild, Reduce, Recover, Repurpose, Restore, Refurbish, Recondition, Renovate
Offline cgroen
    • Carstens personal web
« Reply #40 on: September 22, 2019, 08:28:03 am »
Nice! I'm often checking your channel for new stuff, will be looking forward to some more great stuff from your workshop!
