Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
Nixie tube driver transistor substitute.
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Nixie tube driver transistor substitute. (Read 1416 times)
institches
Newbie
Country:
on:
September 06, 2018, 11:15:25 pm »
I am repairing a 1969 Toshiba nixie tube calculator and have identified a dead power transistor which was the cause of a dead nixie.
I'm looking for a replacement / substitute but not having much luck.
Does anyone know if there is a modern equivalent available for this transistor?
https://datasheetspdf.com/pdf-file/854648/Sanyo/A429/1
Or is there another way I could drive the nixie with modern parts? I don't have any schematics for the calculator unfortunately.
Thanks in advance.
Logged
oPossum
Super Contributor
Country:
Very dangerous - may attack at any time
Re: Nixie tube driver transistor substitute.
Reply #1 on:
September 06, 2018, 11:43:41 pm »
MPSA92 will probably work as a substitute for the 2SA429
MPSA42 is it's NPN compliment and is commonly used with nixie tubes.
Last Edit: September 07, 2018, 03:27:47 am by oPossum
Logged
institches
Newbie
Country:
Reply #2 on:
September 07, 2018, 12:15:27 am »
Thank you very much.
Logged
wilfred
Super Contributor
Country:
Reply #3 on:
September 07, 2018, 12:23:20 am »
What about the MPSA43.
http://www.mouser.com/ds/2/149/MPSA43-115910.pdf
Logged
ArthurDent
Super Contributor
Country:
Reply #4 on:
September 07, 2018, 03:24:25 am »
You don't want the NPN compliment to this PNP high voltage transistor. Check out this list.
https://alltransistors.com/crsearch.php?mat=Si&struct=PNP&pc=0.15&ucb=150&uce=150&ueb=5&ic=0.03&tj=75&ft=50&cc=7&hfe=40&caps=TO92&r1=0&r2=0&r1r2=0
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
