Ive got my Hands on a defective active shelf speaker, which will turn on, Display working, but no Sound comes out. So besides a ADC, there is a DSP (D2- 92633 LR) and a class D (digital in) amp Chip ( TAS5352a).
So besides a defective 12v Buck converter, which was for powering the amp Chip Up, i have a unchanged Signal coming out of all 4 Outputs of the dsp. Its just a rectangle signa, that doesnt Change at all when signal gets fed into the speaker. The Input signal is changing, jittering when i play music, so thats fine till this Point. And even when the amp chip is powered up, i cant hear any noise coming out of the speaker, which may be the cause of the unchaning Input Signal of the amp Chip?
Idk If im Missing something, or if the dsp is just broken (what i dont think) so maybe someone has an idea what to look at next.
