I had 5.1 Pioneer VSX-321 600w perfectly working that I left in a box for 3 years without touching it. After all this time I tried it again and no sound is coming out from central and subwoofer channel. The problem comes from the amplifier, not the speakers.
My idea of electronic in general is below than none so I just brought it to repair. The problem is that one guy couldn't find the issue and suggested me to buy a newer device. And someone else tried to charged me more than if I buy a second hand one (and probably working since day 0). I'd like to try my last chance here. I can try to fix it myself with some help. At least I have a welder and some hope. Not a multimeter but I could get one if necessary.
This is what I tried to identify the issue:
- Move the speakers to other channel to check they work fine and double check the problem is the amplifier
- Apply some heat directly on the area where I connect the speakers wires just in case the weld is loose
- Check for capacitors. Can't see fluid coming out or any bigger than others
- Check motherboard from both sides trying to find anything weird
- Reset the device to factory settings
- Speakers mode test to try speakers separately with a buzz. So no sound configuration is affecting the channels
- Check transistors and apply extra weld as suggested here with similar issue and device:
https://youtu.be/0S4o8Xcc-3EI took some pictures:
https://ibb.co/JrWYpG0https://ibb.co/q5QX2Yzhttps://ibb.co/JvWqn4Zhttps://ibb.co/nRC7nrzhttps://ibb.co/ygSVkrphttps://ibb.co/TPftQDVhttps://ibb.co/0yjyQ5hhttps://ibb.co/Q8pKrpftransistors:
https://ibb.co/g9q81JShttps://ibb.co/hgWf8J5Not sure if this is enough information. Let me know anything and I'll try it.
Thanks everyone!
