Author Topic: Noisy Coil (inductor)  (Read 767 times)
Offline hpibmxTopic starter
  • Country: my
« on: November 12, 2021, 04:28:55 am »
I’ve come across few motherboards iPad and a laptop.
Right after power on I can hear very small noise sound, found out when coil windings get lose they start making noise when current passing through them.
So my question is how can I spot one? I’ve more than 20 in the iPad motherboard. Is there anyway I can find out which is making this noise?
Thank you in advance.
Offline amyk
Re: Noisy Coil (inductor)
« Reply #1 on: November 12, 2021, 04:46:58 am »
Stethoscope. You can make a usable one out of a rolled sheet of paper.
Offline EEEnthusiast
  • Country: in
  • RF boards, Precision Analog, Carpentry
    • https://www.zscircuits.in/
« Reply #2 on: November 12, 2021, 06:06:20 am »
By touching them. The noisy one will get a bit quiet, once you put your finger on them. I guess if they are making enough audible noise, then they are big enough to touch them one by one.
Making products for IOT
The following users thanked this post: hpibmx
Offline jonpaul
    • IEEE Spectrum
« Reply #3 on: November 12, 2021, 07:34:53 am »
Poor SMPS stability and subcycle oscillation.
Due to sloppy Chinese design
j
An Internet Dinosaur...
