To clarify my statement above about capacitance in carbon composition resistors:
I had an application where I needed a high-value (1 M) resistor to bias a JFET gate, but I needed a high parallel resistance at 10 MHz. The parallel capacitance could be tuned out in the circuit. We tried different resistor constructions, and I was disappointed by old-fashioned Allen-Bradley molded carbon composition resistors. Researching this (pre-internet) effect, I found that the talc particles in the composition mix tended to short out nearby carbon particles at high frequencies, resulting in a lowered equivalent parallel resistance. This was confirmed by careful measurements with RF impedance measuring equipment. We replaced the CC resistors with a "carbon ink" formulation from IRC, in the same physical (leaded) size, which is probably now obsolete. Since then, I have found that the "flame-proof" cermet resistors are reasonable at this frequency range, along with thick-film surface-mount parts.
