Author Topic: not a repair as such but here goes  (Read 1645 times)
Offline m3vuvTopic starter
« on: January 21, 2021, 02:44:39 pm »
Hi all,i have a kenwood dso,the rtc battery was flat when i got it,i changed that but still the clock wouldnt keep time,after some poking about i changed the xtal+associated caps around the rtc,the original rtc battery was soldered on to the pcb,i fitted a holder for a lithium 3v cell (the original battery was twice the size),it had no markings!,i assume 5 or 6v,the replacement works but only lasts a few months,could i replace it with a 18650 cell in a holder and tap off a 5v supply for a tp 4056 charger modual,or is that asking for trouble,there is just about room inside to do this,what do you think?,cheers Paul.m3vuv
Offline CJay
Re: not a repair as such but here goes
« Reply #1 on: January 21, 2021, 03:19:15 pm »
What markings were on the original cell?
I don't think constantly charging a cell is a great idea.
« Reply #2 on: January 21, 2021, 03:22:05 pm »
there wasnt any,just yellow shrink wrap,looked to be like 2x cr2032 cells stuck together by the look of it.
Offline CJay
« Reply #3 on: January 21, 2021, 03:34:22 pm »
From your description it could have been anything, NiCd, NiMh, lithium, manganese dioxide, it could have been 1.2V, 2.4V, 3V or more than 6V, difficult to tell what it was definitively, I assume you've disposed of it?
Edit (and yeah, you did say there weren't any markings)
What's the model number of the 'scope?
« Last Edit: January 21, 2021, 03:38:52 pm by CJay »
« Reply #4 on: January 21, 2021, 03:49:34 pm »
its a kenwood DCS-8200
Offline CJay
« Reply #5 on: January 21, 2021, 04:21:47 pm »
Oh wow,there's nothing out there on the net.
Are you able to take some pictures of the board which show the chip markings better, the ones you've taken before aren't readable?
Offline aqibi2000
Tinkerer’
Offline S. Petrukhin
  • Country: ru
« Reply #7 on: January 22, 2021, 09:48:29 pm »
After all, you talked about this earlier and the problem was solved...
And sorry for my English.
« Reply #8 on: January 25, 2021, 07:57:14 am »
was it?,if so for who??
« Reply #9 on: January 25, 2021, 08:25:05 pm »
admittedly,the issue was solved ish but only short term,thats why im asking about this,seems logical to use an 18650 with a tp 4052 charger ic,that was the whole point of the post.
  • Country: ru
