and you think 150mA is bad because?
No, I just wanted to find the highest loads and if it is on the "right" side of the inductors (to find shorted switching MOSFETS).
I also wanted to inject external voltage, eventually.
You could also try this on the Vcore rail with PL1 removed but I don't know what max voltage that should be - can someone educate me here please?
Googled CPU type: SL7EN, RH80536 1800/2M -> Pentium M 745, 1.276–1.34 V.
Have you removed the PL2 inductor yet? If you have one, you could try a bench power supply on load side of PL2 to ground. Set it for 1.2V and CC mode then send an amp or so down the voltage rail and see if anything warms up. You may have to increase the current to a few amps.
You are talking about 19V rail (PL2 is still in place)?
I injected 2,5V @19V rail (DC-in), current is 1.5A.
GPU is getting warm. On higher voltage/current it's getting warmer (and faster), so I did this only for a few seconds.
I know, it's getting warm at normal operation, but I don't know how far can I go with removed heat sink.
@carl_lab
If it doesn't want to come out of hte socket, try heating the CPU with a hair dryer, or freezing it, and see if the resistance from the PL1 inductor to ground changes. Without heating or cooling other components if possible. Do this with your DMM set on the lowest ohms range it has. If you don't see any change in resistance try heating or cooling the whole board and try to narrow down the area which makes the resistance change the most (assuming it does change).
I heated CPU, GPU and the third "CPU-like" (bridge?) IC using a heat gun (not too hot, ~60-70°C):
The only one that showed a reaction was GPU (currrent increase from 1.5 to 1.8A @Vin=2.5V ).
I think changing load over temperature would be relative normal (it's a semiconductor).
I also think the problem is a permanent one, not a temperature problem.
GPU supply, I measured at one of the bigger ceramic caps at the backside of the GPU, is about 1.85V @Vin=2.5V (2.1V @Vin=3.0V).
That's the same voltages (1.85V, 2.1V) I can measure at PL12.
That's 1.2V rail, the voltage is to high.
Found shorted high-side switching MOSFET (PQ59) !
Removed PL12 to inject 1.2V from external supply.
Current is 450-500mA. GPU stays cool, so I hope, it's not damaged.
I will remove MOSFET (PQ59) and try to get replacement...
