Info about the card,
Before taking it apart I installed and tested it. The pc would boot up, I would enter password for win10 64, desktop loads and then 30 secs later pc reboots. Fan runs, card LED light up, 6+8 gpu power connectors light up blue. Figured I would check the thermal paste so I opened it and the paste was all over the die and out over the capacitors, there is still small amounts of paste caked around the edges of the caps. Thanks for the info on the caps being in parallel sounds like they are overkill. Any thoughts on the pc rebooting after loading the desktop? The pc currently runs 2 gtx 670 in SLI and drivers are up to date, pc runs fine with the 670's but no luck with the 1080ti
