I think I figured out the pinout, 1 and 2 are in the upper left (close together) and are +12v. 3 is ground, lower left. Not seeing any output unfortunately, either I was sent a bad part of I popped it trying to figure out the pinout. Not sure which is the VCO and output, but I suspect VCO is across from the VCC and the output is across from ground. I can see proper operation of the Oven, no output though.
Found a photo of the 08920-61192 OPT REFERENCE card for the 8920A.
