So I bought two Morion MV89A, one for use in a GPSDO and the other for upgrading the timebase in my 53131A. Turns out one of them is totally dead, of course its the one in better physical condition too, since the one that works had a completely sheared off ground pin. I ended up making a new pin on a lathe out of brass, which seems to have repaired the one with a missing pin, so I'm at 1 for 1 so far.
The other one is a little more complicated, since it has zero signal output. It heats up, so the oven works, but no output. What are the odds this is salvageable? I saw some people mentioned I might be able to open it with a blowtorch or high power heat gun, but wanted some input before I did the irreversible.
From anyone who has opened up a soldered case OXCO before what worked best for you?
Edit: I did find a post by someone using the exact same OCXO as me, but would still love some input before getting out the torch.
https://rbarrios.com/projects/mv89a/
