I bought this old HP 8660 RF generator about 10 years ago. It was listed as working on eBay. After doing an initial checkout, found it had a problem. Once I took it apart, I noticed someone had made a note on it about the problem. Rather than replace the bad parts, they had jumped them out. It has not had any problems since I went over it.
I went to use it the other day and the output level was really low. Pulled it apart and checked all the voltages, all good. Checked at the oscillators in the mainframe, all good. Pulled the covers off the RF section and pulled out the board I had repaired way back when. It looked fine. Installed the RF section and it all works.
I hate intermittent problems.
