Might also machine the sleeve to be oversize internally, and use a thin extra insulator, just in case the cell sleeve is conductive, no need to make a impromptu electric gun if the alkaline cell shorts out. Another idea is to use a cutter that shapes the negative contact inside to be a dome shape, so there is less chance of shorting, or just make a pip on the outside and sleeve the whole item as a positive side use item, so that you need no inner insulation for a typical AAA alkaline cell, which typically uses a negative end seal.
