Author Topic: Old Battery charger  (Read 2978 times)
Offline filtatosv6Topic starter
  • Country: gr
Old Battery charger
« on: October 15, 2015, 07:39:10 pm »
Hi I recently got an very old battery charger with variable output that had a problem with the bridge rectifier and the volt meter.
There is no capacitor inside so the output is 100Hz rectified sin wave.
I was trying to calibrate its volt meter when I realized that I don't know where to calibrate it.
I wonder what the battery sees. Is it the RMS?, the Vmax? Or what I read in DMM in DC mode???
e.g. in the first setting the output is
17Vmax
12V RMS
10.5V DC
If for the sake of the argument I wont to charge a car battery what output do I need???
ps i hope i explained it clear enough. English is not my native language.
Offline tautech
Re: Old Battery charger
« Reply #1 on: October 15, 2015, 08:00:05 pm »
Welcome to the forum.
Interesting it has a Voltmeter, normally an Ammeter is used to monitor charging current.
For general car battery charging up to 14.5V is not considered excessive, although I tend to stay just below that  @~14.2V. Over 15V is called a gassing charge and is sonetimes used for Automotive battery maintenence. This requires replenishment of lost water as a result of the gassing/bubbling.
Avid Rabid Hobbyist
Offline oldway
« Reply #2 on: October 16, 2015, 10:55:43 am »
Voltmeter is provided to measure battery voltage and must be calibrated with DC. (for exemple from an external power supply).
When battery is connected, output voltage of the battery charger is filtered by the battery and ripple is low.
You said that this battery charger has "variable output", I think you means that there are several taps on the transformer with a comutator to select one of them.
This is intended to ajust charging current.
As there is no voltage regulation, battery voltage of a fully charged battery will be close to the peak output voltage of the battery charger.
This is often too high for modern batteries. (as Tautech said, may never be higher than 15V !)
  • Country: gr
« Reply #3 on: October 20, 2015, 06:46:36 pm »
Sorry for my absence.
Thank you for the welcome. I didn't say anything because I don't feel new to this forum. I am reading it as a quest for some time now.
You got it right although the taps from the transformer give different volt outputs, up to 30V (Vp much higher) and the meters ware for AC. I wouldn't trust it
Any way thank you for your answers.  :-+
Offline oldway
« Reply #4 on: October 21, 2015, 07:01:28 am »
That is no load voltage and it does not mean nothing because secundary voltage is limited by the battery.
Transformers for battery chargers have a high short circuit voltage (above 20%) to limit charging current.
NB: short circuit voltage is how much % of nominal voltage you have to apply to the primary to obtain the nominal current with the short circuited secundary.
In normal working, you switch the taps to ajust the charging current.
AC voltmeter (moving iron) may also measure DC voltage.
What you should look for is if it measuring voltage before or after the rectifier.
« Last Edit: October 21, 2015, 07:06:13 am by oldway »
  • Country: gr
« Reply #5 on: October 21, 2015, 07:55:30 am »
Definitely after the rectifier. It is parallel with the output.
« Last Edit: October 21, 2015, 07:57:50 am by filtatosv6 »
Offline oldway
« Reply #6 on: October 21, 2015, 08:29:17 am »
As I said, this voltmeter is intended to measure the battery voltage and must be calibrated with DC voltage from an external power supply. (battery charger NOT powered on !)
When battery voltage reach 14V, you must stop charging the battery.
Offline mikerj
« Reply #7 on: October 21, 2015, 10:26:54 am »
I've never heard leakage inductance described in those terms, is this an industry standard  measurement?
Offline oldway
« Reply #8 on: October 21, 2015, 10:54:42 am »
Impedance voltage is relative short circuit voltage, when secondary of a transformer is short circuited, and we are slowly raising the primary voltage "Vpr" until the current at the secondary reaches its nominal value. The ratio of the "Vpr" and nominal voltage of the transformer is called impedance voltage. It usually goes from 3% to 20%.
https://www.physicsforums.com/threads/impedance-voltage-of-a-transformer.571998/
Ucc = short circuit voltage.
See specifications of transformers:
For example,
http://www.erea.be/frontend/files/certificates/72_catalog-en-ed-2013.pdf
This is a transformer from a 12V  6A battery charger.
Primary and secundary are wound side by side to increase magnetic leakage and short circuit voltage. (more or less 20%)
« Last Edit: October 21, 2015, 11:24:56 am by oldway »
