The resolution of the d'Arsonval movement is on the order of 1%, with similar linearity. Therefore, 1% metal-film resistors are probably sufficient to replace the four in the network. You probably need to use two in series to achieve the values required for some of the resistors. The overall accuracy, including the calibration of the microammeter, can be adjusted with the trimpots for different functions.
