Hello everybody
The manual here http://pacifictv.ca/schematics/eico460manual.pdf page 15 and correction here http://pacifictv.ca/schematics/eico460addendum.pdf
On the photo the 2 paper capacitors C25 and C26 which are also waxed, there is a liquid between the two which flows and that left a drop in the bottom of the case. It looks a bit like varnish, it's translucent yellow, a little thick, odorless and a little oily. Is it the wax that melts? Yet it does not harden and I do not see any cracks or anything abnormal from the outside. I have desoldered a pin of each capacitor to check their capacitance and it's ok on that side, C25 = 0.09934µf and C26 = 0.1107µf. These are .1µf-1600v.
On the other hand the capacitor C28, according to the manual should be a 50µf-50v and that which is there is a 250µf, 35v, -20°+70°C. Is that causing a problem because I thought I would change it to a 47µf, 50v, 85°C.
Thank you and happy new year! :-)
They are "Waxed Paper capacitors" The stuff which looks a little oily is the wax.
It tends to break down chemically over a long time, with heat & other environmental conditions.
A brand new capacitor of this type will look a lot more "waxy" on the outside, but old ones have often lost a lot of that surplus wax, leaving the "wax-like" deposit on the bottom of the case.
They are
not "oil" capacitors, which are a different breed of beast, altogether.
They are replaceable by Polyester, or Polycarbonate capacitors, or probably several other types.
The voltage rating will be the problem, as not so many high voltage caps are made these days.
A component of the same capacitance with an equal or better voltage rating should be OK.
