Hi guys,
This post comes off the back of a previous post I made
here.
I'd like to try and get this drive working (as finding a suitable replacement for a reasonable price is proving difficult). The error that is being generated is "Code 4 - Index pulse not detected during spin up". The manual describes the following power-up procedure:
+12 VDC powers the spindle drive motor. The microprocessor verifies that the disks are spinning at 3600 rpm and then activates the automatic Track Zero positioning. -TRACK ZERO, -SEEK COMPLETE, and -READY will become true upon completion of the Track Zero positioning sequence. Further on down the manual, it goes on to specify:
-INDEX This 300 microsecond (typical) interface pulse is provided by the drive once each revolution (16.67 ms nominal) to indicate the beginning of the track. Normally, this signal is a high level and makes the transition to the low level to indicate -INDEX. Only the transition from high to low is valid.In my case, the motor is spinning fine. I can physically see it make several full rotations upon power-up before shutting off with the error code. There are other error codes which relate to the actual speed:
Code 5 - Unable to reach 3600 rpm in 30 seconds
Code 6 - Unable to stabilize spin speed in 10 seconds
Code 7 - Unable to maintain spin speed to 0.5%As I'm not getting these errors, this indicates to me there is absolutely no output from the sensor at all.
One of the forum members, Chris, posted this:
You do not have to remove the cover to check the index sensor, its located under the PC board, I remember the filecards and the 8438 RLL drives.
I've pulled the PCB off the drive and found what appears to be the index sensor. There is a small silver circle (
A) on the edge of the motor which passes a small black piece (
B) as it rotates. Now I'm stumped at where to start troubleshooting. What kind of sensor is this?
Unfortunately I don't have a scope to probe around with (Dave, interested in a repair video?)
