Old PC Power Supply
Posted by
RyanG
on 15 Jul, 2019 20:04
I have a LITEON 200W power supply that is pretty old. I'm trying to repair it because it doesn't turn on.
I checked the caps with an ESR meter and looked for burns or other physical damage with none found. I also checked the solder joints on the board, and they all look good. The switches for the mains voltage tested good and I do get voltage at the main switching MOSFET of around 160v.
The only problem I have found is that when I check the voltage on any pin of the UC3844 at the bottom right of the picture I get -160vdc on every pin. And, checking the voltage from the drain of the MOSFET to the any pin of the UC3844 I get 324vdc. Any help would be appreciated. Thank you
#1 Reply
Posted by
bob91343
on 15 Jul, 2019 21:06
First see if the circuit is oscillating properly. If not, troubleshoot the feedback loop. You may have a failed transistor or diode.
If it oscillates, then you should see a nice big wave on the main FET. Verufy transformer winding continuity. Look for shorted diodes.
It's important to understand how the circuit works before you hurt yourself. The voltages get high and at this power level can be very hazardous.
And use an isolation transformer if you probe with an scope on the primary side.
#3 Reply
Posted by
RyanG
on 16 Jul, 2019 00:03
I don't have an isolation transformer at the moment. I have one at work for fixing the CRT power supplies I do there, but I can't get it right now.
I never get any voltage on the UC3844's VCC pin, but the OUTPUT pin has some voltage on it, around 0.5v.
The primary side of the main transformer looks good. All of the pins on the secondary side have a resistance of less than 40 ohms between each other.
It has 2 schottky diodes on a shared heatsink. One of them looks normal with around 0.2v drop on each of the diodes in it while the other has around 0.01v drop on each. That is testing them in circuit.
#4 Reply
Posted by
xavier60
on 16 Jul, 2019 00:31
First make sure that the design has a bleed resistor from MOSFETs Gate to ground to stop the Gate drifting high while in the fault state.
Look for high value resistors that supply start up current to the UC3844's VCC pin.
More: The start resistors often serve as bleed resistors for the large capacitors. Check for residual charge before touching it.
#5 Reply
Posted by
RyanG
on 16 Jul, 2019 01:10
There is around 20M
between the gate and GND on the UC3844, so I am guessing there is no resistor there.
There is around 500k
between the VCC and the high voltage rail.
#6 Reply
Posted by
xavier60
on 16 Jul, 2019 01:17
There is around 20M between the gate and GND on the UC3844, so I am guessing there is no resistor there.
There is around 500k between the VCC and the high voltage rail
Check for residual charge on the large capacitors. As a precaution, add a resistor between Gate and Source, 10K to 100K.
The 500K seems too high. Remove and check the high value resistors.
#7 Reply
Posted by
RyanG
on 16 Jul, 2019 01:19
This PSU has a 115v/230v switch on it, and it appears that on the 115v setting it powers the UC3844 from the negative high voltage, which would explain why I was reading 324v between the MOSFET and the pins of the UC3844
#8 Reply
Posted by
RyanG
on 16 Jul, 2019 01:31
I added the 10k resistor across the gate and source.
I had the transformer out when I measured the resistances earlier. So, there is about 30k to the positive high voltage rail from the VCC pin on the UC3844
#9 Reply
Posted by
xavier60
on 16 Jul, 2019 01:47
For the UC3844 to start, its VCC voltage needs to reach 16V from the start resistor then it gets powered from a rectified transformer winding if the PSU starts normally. The voltage on the VCC pins needs to be maintained above 10V.
After replacing the VCC pin's bypass capacitor, it's best to monitor any activity on the pin with an oscilloscope as mains is applied via an isolation transformer.
#10 Reply
Posted by
RyanG
on 16 Jul, 2019 02:07
I replaced the VCC cap, but the voltage only goes up to about 1.8v on the VCC pin.
#11 Reply
Posted by
fzabkar
on 16 Jul, 2019 02:20
I agree that 500K seems too high for the start resistor. I would have expected something like 100K - 150K.
#12 Reply
Posted by
xavier60
on 16 Jul, 2019 02:27
There might not be enough start current or leakage path to ground.
Have the high value resistors been checked?
Add a 1k resistor from VCC to ground and measure the voltage drop to calculate the start current.
There could be protection circuitry that is locking down VCC after some delay period or after the first failed start attempt.
#13 Reply
Posted by
RyanG
on 16 Jul, 2019 02:31
I can see that the VCC pin is connected to the cap then through a low value resistor then a diode to the transformer, which is what will hold the voltage after it starts.
Following the traces away from there it goes to a 1k resistor and a 2N4403 and then through another 1k resistor to a 2N4401, but I haven't followed those transistors yet.
#14 Reply
Posted by
xavier60
on 16 Jul, 2019 02:48
The complications on the VCC pin will need to be traced out and made sense of.
Have the output diodes been fully checked?
Is there any brief sound from the PSU when mains is first applied?
#15 Reply
Posted by
RyanG
on 16 Jul, 2019 03:51
I don't hear any sound. I replaced the output diode that I thought was a problem with another and I had the same problem.
I guess I should have posted the model before, but it's a LITEON PA-4201-9A
#16 Reply
Posted by
xavier60
on 16 Jul, 2019 04:03
There appears to be yellow glue on the PCB. Where is has turned brown, it can cause problems by direct leakage or by damaging components that it's in contact with.
After is is removed, remaining invisible residue also needs to be removed with a solvent.
#17 Reply
Posted by
xavier60
on 16 Jul, 2019 04:49
It is common for small glass diodes to be damaged by the glue's corrosive state.
To properly clean the PCB, some components will need to be removed.
If the transformer and large capacitors are removed, the PCB can then be finally washed with hot water and dried.
#18 Reply
Posted by
fzabkar
on 16 Jul, 2019 05:20
@RyanG, I notice that you have been asked 3 times to check the value of the startup resistor, but AFAICT you have not.
See the application circuit on page 11 of the UC3844 datasheet:
https://www.onsemi.com/pub/Collateral/UC3844-D.PDFNote that the circuit is for a 115VAC supply. Your circuit will have a voltage doubler, so the 56K resistor in the application circuit will need to be increased to 120K or thereabouts in your case.
#19 Reply
Posted by
xavier60
on 16 Jul, 2019 05:37
When some of the larger components are removed, it will also be a good opportunity to remove and check the start resistors.
If that's really decomposed glue at each side of the MOSFET's heatsink, it must be clean up before powering the PSU again.
Care needs to be taken so as to not damage and obscure the value of resistors covered with glue.
I would suggest de-soldering any vunerable resistors to measure and note their values before being disturbed.
Also try to note their markings at the earliest chance.
#20 Reply
Posted by
RyanG
on 16 Jul, 2019 05:49
I have checked for the resistors and the highest resistor I can find in the area around the UC3844 is 12k. See attached picture. I have cleaned the glue to the point where it doesn't touch anything but the heatsink.
I'm up to 1.9v on the VCC pin now.
#21 Reply
Posted by
xavier60
on 16 Jul, 2019 06:01
The decomposed glue needs to be cleaned from all areas where it can cause problems. There could be more hidden by the heatsink where I suspect that the opto-coupler/s is/are. How many are there?
The start resistors will be physically larger. They could be near the large HVDC capacitors. What is that smaller electrolytic doing there?
#22 Reply
Posted by
RyanG
on 16 Jul, 2019 06:10
There are two 100k resistors, one across each of the big capacitors.
There are two low value resistors going to the source of the MOSFET.
There is one big 5W 22k resistor above the heatsink.
Those along with the picture in my previous post are all the resistors on the high voltage side of the board.
I pulled the heatsink and cleaned all the glue
#23 Reply
Posted by
xavier60
on 16 Jul, 2019 06:13
What about the smaller capacitor near the large HVDC capacitors? How is it wired?
#24 Reply
Posted by
RyanG
on 16 Jul, 2019 06:21
The negative side of the small capacitor goes to the positive side of one of the large capacitors and one winding of the transformer. The positive side is fed from the drain of the FET through a diode. The big 5W resistor is in parallel with the small capacitor
