Well, for those still paying attention, I found a Micronta MultiLab tester on eBay. Unfortunately, it does not work, at least not totally. From what I can tell. the actual meter itself is non-functional. I can select the 15v range, connect a 9V battery and...nada. No meter movement. I have verified that there is voltage at the terminals on the back of the meter, but it will not deflect. The R/C substitution works, but I haven't been able to test the AF/RF generator. And the RF signal strength...well, no meter, no measure.
I'm still looking for the Micronta Home-Auto Tester. I have found several variants, from CalRad, Midland, Eico, and even one from Elenco. I did find a "Handi-Tester" from National Technical Schools, brand new, still in the box a previous owner received it in, with a postmark of 1984. When I opened the tester, I found a 36-year-old Ray-O-Vac AA battery that, to my surprise and relief, had not leaked. And it measured 1.2V. It is similar to the Home-Auto tester, but has separate jacks for the various functions/ranges instead of a rotary switch. So far it works perfectly. And like the Home-Auto tester, you shouldn't try to measure anything with the leads when the line cord is plugged in because one side of the line cord is connected to the "Common" jack. Definitely wouldn't pass UL testing. Oddly enough, a later revision of the Elenco version of the Home-Auto tester has a switch to isolate these. It has a note included in the box mentioning the switch and why.
