Author Topic: Old Rubycon SH-series capacitor from the 1980's.  (Read 1907 times)
Offline JDW
  • Country: jp
« on: September 12, 2019, 09:34:52 am »
I'm replacing the capacitors in a SONY power supply used inside an old Apple HD20SC hard drive enclosure.  These were released in 1986 and mine seems to have been built in 1987 or 1988.  It worked before recapping and still works after recapping but there's a short beep (squeal?) that occurs at the time I switch on power.  I traced the trouble to a single Rubycon cap.  My replacement for the stock Rubycon SH-series 10V 2200uF capacitor is a Nichicon UHE1C222MHD1TO. It didn't make that squeal sound when I had the stock caps inside. And when I remove that one Nichicon and put back the Rubycon (only that 1 cap -- all the rest are my replacements), the beep goes away. Viewing the 5V rail on the scope shows a tad bit more noise (ripple) with my Nichicon replacement, but I believe the problem is that my replacement's ESR is too low, causing either a phase shift or unwanted oscillation.
I measured the Rubycon cap with my DE-5000 meter. At 120Hz it shows an ESR of 0.2-ohm. My replacement Nichicon is much less than 100-ohm -- so low the meter won't show the value at 120Hz.
Here's a photo of the stock Rubycon cap:
832866-0
It measures D=13mm, H=26mm.
Do any of you have an old datasheet for the Rubycon SH-series? I can't Google up anything.
The problem is I am not finding any 10V 2200uF replacements on Mouser that would fit D=13.5mm(max), H=29mm(max) and have sufficiently high ESR. The ones that fit all have a quite low ESR specs. I don't have a schematic of this power supply, so a datasheet on the Rubycon would help a lot. Any ideas or suggestions would be appreciated.
Thank you.
Offline OwO
  • Country: cn
  • RF Engineer @ OwOComm. Discord: スメグマ#2236
Re: Old Rubycon SH-series capacitor from the 1980's.
« Reply #1 on: September 12, 2019, 09:54:23 am »
add a resistor
Discord: スメグマ#2236
Email: OwOwOwOwO123@outlook.com
GitHub: gabriel-tenma-white
Offline PKTKS
  • Country: br
« Reply #2 on: September 12, 2019, 10:21:06 am »
In 80's and 90's -pre internet and  practically pre the networked "PC" ...
 (XT/AT in rare cases would have a modem if someone would paid the phone bill...)
There were no "datasheets" as we know it today.
"MANUALs" were the only source of those prints and unless
you hard copy them you would have to buy one (very expensive
large size bibles..)
So *UNLESS* you can find the "SCANNED" version of one
of those old stuff... or one single page hard copy..
chances are we have no clue about that.
Even founding some sheets they are hardly comparable
to some recent today almost machine based generated sheets.
Another era another tools.. those pages are part of other class
of tools.
I do have some large "stuff" crammed in folders (papers)
which is hard to replace hard to find and hard to get rid of...
digital stuff is another level of problem..
they do not suffer dust problem but you do need backups.
Paul
« Last Edit: September 14, 2019, 04:12:06 pm by PKTKS »
Offline jfiresto
« Reply #3 on: September 12, 2019, 11:07:43 am »
large size bibles..)....
Huh? You just rang the local sales office and they would happily send you datasheets, or complete data books, if they liked to provide data in aggregate, to encourage people to design in other parts.
Rubycon may have an archivist who can send data for discontinued parts.
Offline PKTKS
  • Country: br
« Reply #4 on: September 12, 2019, 11:16:58 am »
May be in some very specific areas with such representatives.
But not "around the world" and due to costs probably not for free.
Even my  CMOS (National) and TTL databooks costed me a little
fortune those days...  hard to obtain and very expensive.
Paul
Offline jfiresto
« Reply #5 on: September 12, 2019, 12:12:34 pm »
... Even my  CMOS (National) and TTL databooks costed me a little
fortune those days...  hard to obtain and very expensive....
If you were in Brazil back then, did you try the sales office in Sao Paulo?
I found National was always very helpful in answering requests. They would sometimes even send a sample or samples, when I just asked about a datasheet, if they thought it might help the evaluation and design.
Offline PKTKS
  • Country: br
« Reply #6 on: September 12, 2019, 12:46:45 pm »
IN early to mid 80's Brazilian electronics industry was still active...
today no longer the case, practically all stuff is imported.
But those days there was interest from the representative sales
office to promote their stuff so although quite expensive the
literature was indeed available.
Never free. Several reasons..
 +PLUS nasty just beyond insanity brazilian taxes...
Nevertheless I managed to have at least Philips, National
Texas and some Intel and Zilog stuff..
Still carefully stored although paper is something hard to conserve
Paul
Offline shakalnokturn
« Reply #7 on: September 12, 2019, 04:29:26 pm »
No datasheet sorry...
I'm assuming this cap is the first after the rectifier on the rail that has the regulation loop? (Opto)
As suggested the quick way round would be adding a little series resistance.
You could also consider modifying or adding soft start, but I bet you want to leave this collection piece as close to original as possible... (Do the caps even need replacing?)
Offline JDW
  • Country: jp
« Reply #8 on: September 12, 2019, 09:31:59 pm »
 Fluid filled electrolytic capacitors do not have eternal life, folks. They don’t last forever. I also see evidence of leaked fluid. And even when you don’t see evidence of leaked fluid, it’s very well may be that some of the fluid has dried out through the years, especially in power supplies where there’s constant heat. So yes, after 30 years, these capacitors do indeed need to be replaced.
 I don’t have a schematic for this power supply, and I don’t think one is readily available because I cannot Google it up.
I actually started soldering three 1/8W .5 ohm resistors in parallel to give me 170m-ohm of resistance, but I found when I tried to solder that cap and resistor in there wasn’t enough space. It comes dangerously close to other high-voltage components. I’m also not sure of what the wattage spec should be on such an in-line resistor, although three 1/8 wide resistors in parallel could be enough. I just don’t know.  But it doesn’t matter when there’s not enough space.
 None of you suggested a high ESR replacement capacitor, so I guess you don’t know?
Online Yansi
  • STM32, STM8, AVR, 8051
« Reply #9 on: September 12, 2019, 09:38:16 pm »
A classic example of "fixed until broken completely".
Why have you changed the caps, if it was working fine? Age isn't enough argument to replace them.
« Reply #10 on: September 12, 2019, 10:51:15 pm »
Not saying JDW is a case of fix until broken... Sometimes components do need replacing sometimes it's even worth replacing them before time because you know that if you wait long enough you'll be having a whole lot more fun getting the thing working again, if possible. (Nichicon SMD electrolytics on Mac classic mainboards are one example.)
It's the "replace all the electrolytics" approach that some people have that I can't agree with, often there's no point, if it's to tear out perfectly good enough caps to throw in budget far east Yaego-cheapo replacements that won't last 1/2 as long as the old originals remaining lifetime it just seems a waste.
Don't know of specific high ESR electrolytics, I'm sure some vintage Tektronics people do, it's a problem that's mentioned regularly WRT to old Tek equipment.
Maybe a Parametric search on Mouser, Farnell, RS... will give you an option to filter only the highest ESR models?
Offline JDW
  • Country: jp
« Reply #11 on: September 13, 2019, 12:23:32 am »
Not saying JDW is a case of fix until broken... if it's to tear out perfectly good enough caps to throw in budget far east Yaego-cheapo replacements that won't last 1/2 as long as the old originals remaining lifetime it just seems a waste.
Thank you for being more understanding than some inexperienced people who have never dealt with vintage Mac motherboards destroyed by leaked capacitor fluid which ate through traces!
My replacements are mostly Nichicon, 5000hr or 10,000hr and of the highest quality I can find. So swapping best-quality modern caps for those 30+ years old is not a waste at all.
I did a parametric search on Mouser but I cannot find anything that will physically fit.  Another problem is, without any kind of data on my stock Rubycon SH-series capacitor, my parametric search is somewhat in vain.  Consider that most datasheets only specify MAXIMUM ESR.  I don't know that spec on my Rubycon, and guessing isn't good.  I only know what I can measure, and it's 0.2-ohm according to my DE-5000, @120Hz.  I cannot measure higher frequencies, unfortunately.  (My DE-5000 fails to do that on most large capacitance devices.)  And again, I lack the physical space to add a series resistor.  And on top of that, I'm not really sure what wattage rating would be best even if there was space for such a resistor.  Do you?  (No, I don't have a schematic.)
Offline JDW
  • Country: jp
« Reply #12 on: September 14, 2019, 04:43:26 am »
I usually share my recapping knowledge with others in the form of a replacement capacitor list, so a readily available replacement capacitor that works well is critical and is why I started this thread in the first place.
Using my DE-5000 meter, I made the following measurements today spanning several minutes for each test to ensure the most accurate measurement, all at 120Hz because higher frequencies produced no results on my meter...
Stock Rubycon 2200uf 10V capacitor (SH-series, 105°C) (inside Sony PSU in Apple HD20SC):
• θ = -75°
• Q = 3.7
• R = 0.1Ω (only the tenths place was shown, so it could be 100, 150, etc.)
• D = 0.270
Nichicon 2200uf 16V capacitor (UHE1C222MHD1TO, 105°C):
• θ = -88.6°
• Q = 45
• R = 0.0Ω (only the tenths place was shown, so it could be 20mΩ, 60mΩ, etc.)
• D = 0.022
LCC 2200uf 25V capacitor (new but 16.5 years old, 85°C):
• θ = -87°
• Q = 20
• D = 0.049
Note that D is Dissipation Factor, aka tan δ, which is almost always shown in capacitor datasheets even when ESR is not.
After recapping, when I use the stock Rubycon cap, all is well and there is not beep/squeal shortly after I switch on power, and the peak-to-peak ripple on the scope shows as it did prior to recap -- about 50mVp-p.  The ESL spikes are 100mVp-p max.
When I use the Nichicon cap, the ripple is about 70mWp-p and ESL spikes exceed 100mVp-p, and there is a beep/squeal sound shortly after I switch on power.  I don't see a buzzer on this PSU, so I think the sound is coming from one of the two transformers, as per what my ear is telling me.
I then thought it best to try a new but very old cap I got when I bought my JAMECO electrolytic radial capacitor kit back in April 2003 (more than 16 years ago).  That cap too is 2200uF but 25V and rating at only 85°C.  It's marked LCC and I cannot find any data sheet for it.  I doubt JAMECO had these kits in stock for more than 1 year, and I doubt the cap was made more than a year before the kits were assembled, so I would guess the age of the cap could be as old as 18 years.  But again, it was new, never used, and always stored in a location where people are (i.e., no long term temperature extremes or excessive humidity).  With this old LCC cap, there is no beep sound, and the scope measurements are exactly what I see with the stock Rubycon cap.  This is interesting because if you look at my measurements above, the LCC still has much better test results than the Rubycon.  The LCC's Dissipation Factor is more than twice the Nichicon's though, so perhaps that is the key here?  Even so, it's still much lower than the 0.270 of the stock Rubycon.
In any case, the problem is easily solved for me by using either the stock cap or the LCC, but if I share a capacitor replacement list with others, the issue of that one cap is a sticking point.  Sure, I could just advice using the stock cap, but what about cases where that cap is bad?  And so I am trying to find a suitable replacement 2200uF 10V (or higher) cap that will physically fit (13mm x 26mm) and produce a stable output voltage.  I think the beep after the switch-on is telling me of some instability, and the higher ripple voltage of the Nichicon replacement seems to bear that out.
Any further thoughts on this would be appreciated.
Thank you.
Offline fzabkar
« Reply #13 on: September 14, 2019, 05:03:05 am »
Would adding a series inductor prevent the power-on squeal?
Searching for a capacitor with inferior ESR specs just doesn't seem right.
« Last Edit: September 14, 2019, 05:04:36 am by fzabkar »
Offline exmadscientist
« Reply #14 on: September 14, 2019, 05:52:27 am »
As someone who faces similar search troubles when designing electrolytics into new designs, I feel your pain. Many engineers do not understand the value of ESR in a bulk capacitor, and I have gotten some strange looks indeed when saying that a part can have too low an ESR and I need to find something higher. Manufacturers aren't immune, either: new parts advertise their lower and lower ESRs, and I still search out the old cheap ones. I know, I know, I could just add series resistance (and have indeed done so when I haven't had space for an electrolytic), but there's just something so elegant about how many problems a single humble aluminum electrolytic capacitor can solve.
One tip that can help in the search is to remember that ESR and ripple current are inversely related, particularly HF ripple current. (Ultimately the ripple current limit is set by heating, caused by ESR- and dissipation-related losses.) Thus if a part doesn't specify its ESR, but has a lower ripple current rating than comparable capacitors, you can infer that it is likely to be a good choice when you want ESR. Sorting by ascending ripple current on Digi-Key quickly turned up the EEU-EB1A222 as a reasonable candidate for you. (There may be better choices; that's just the first one I found.) As well, physically smaller capacitors are often forced to have higher ESRs due to their construction, so don't limit yourself to a single size if smaller parts might fit.
(Aside: those measurements look a bit fishy. In particular, I am suspicious of those high Q values for electrolytics; you may want to check your meter. But that has no bearing on your main point.)
The following users thanked this post: JDW
Offline JDW
  • Country: jp
« Reply #15 on: September 14, 2019, 06:19:20 am »
As someone who faces similar search troubles when designing electrolytics into new designs, I feel your pain....
Thank you for your honest and experienced opinion.  I appreciate the specific capacitor recommendation very much indeed, and found it in stock on Mouser as well:
https://www.mouser.jp/ProductDetail/Panasonic/EEU-EB1A222?qs=sGAEpiMZZMtZ1n0r9vR22RyzzjEKRzqKYIaKulH23zw%3D
DF@120Hz is a fairly high 0.32 (a good thing in this case), and the rather low 540mA Ripple Current spec indicates the ESR is rather high (also a good thing, I think, as it more resembles what the stock cap was probably like back in the day).  And yet it's rated at 105°C and for 10,000hrs, and from a well respected maker of aluminum electrolytic, making that cap a wonderful pick, in theory.  I will purchase it and put the theory to the test.
By the way, here are photos of the PSU inside the HD20SC drive enclosure, and the bottom photo clearly shows the 10V 2200uF Rubycon I've been talking about.  The beep sound, to my ears, comes from the area of those two transformers nearest to the cap:
https://www.icloud.com/sharedalbum/#B0wGQOeMmGzwJPA
And here is the full list of caps showing the stock capacitance, voltage spec, physical size and lead spacing, with my replacement capacitor part number shown in parenthesis at right:
C226: 22uF 35V, D=5.2mm, Leads=5mm -- (Mouser: UHE1H220MDD1TD)
C202: 47uF 25V, D=5.2mm, Leads=5mm -- (Mouser: EEU-FR1E470B)
C222: 47uF 25V, D=5.2mm, Leads=5mm -- (same p/n as C202)
C109: 150uF 400V, H=32mm, D=25.8mm, Leaders s=10mm -- (Mouser: 860021383023)
C110: 4.7uF 350V H=32mm, D=12.8mm, Leads=5mm -- (Same as SONY C164 - Mouser: UPM2G4R7MHD)
C210: 330uF 16V, D=8.1mm, Leads=5mm -- (Mouser: EEU-FR1E331B)
C215: 470uF 10V, D=8.1mm, Leads=5mm -- (Mouser: EEU-FR1E471YB)
C213: 22uF 100V, D=10.2mm, Leads=5mm -- (Mouser: UBT2A220MPD1TD)
C214: 2200uF 10V, D=12.7mm, Leads=5mm -- (Mouser: UHE1C222MHD1TO) <-- the problem guy!
C209: 2200uF 16V, D=12.7mm, H=30mm, Leads=5mm -- (same p/n as C214)
I knew I needed a "16V" 2200uF cap for C209, so I thought it no harm in going with the same cap for C214 too, but that wasn't a good assumption.
Anyway, I took measurements more than once with my DE-5000 to make sure of the accuracy.  It took several minutes for the DF value to settle though.  It kept rising and rising.  But the biggest frustration with this meter is that it won't show me enough ESR info at 100Hz or 120Hz.  The tenths place isn't enough.  I want to see down to 1mΩ!  I can see that on smaller capacitance caps which allow me to crank up the test frequency, but this large capacitance caps don't let me use anything higher than 120Hz.
« Last Edit: September 14, 2019, 06:23:48 am by JDW »
Offline The Electrician
« Reply #16 on: September 14, 2019, 08:30:14 am »
The DE-5000 has no problem measuring ESR at higher frequencies--you just have to set it to measure Rs instead of Cs and ESR.
Here's a Nichicon 2700 uF measured on a bench meter at 1 kHz:
Here's what my DE-5000 measures at 1 kHz:
Offline JDW
  • Country: jp
« Reply #17 on: September 14, 2019, 08:54:48 am »
Thank you for the excellent tip!  I'll starting doing that from now on.
By the way, I have a Fluke 8845A benchtop meter with 2x4-wire test leads to take precision resistance measurements.  Is it safe for the meter and the cap to measure ESR on large capacitance caps with the meter in Ohms mode?
« Reply #18 on: September 14, 2019, 09:06:42 am »
You can't measure ESR with a DVM--it measures resistance using DC excitation.  ESR is measured with AC excitation.
Offline JDW
  • Country: jp
« Reply #19 on: September 14, 2019, 10:10:30 am »
Which implies that the "Rs" mode of the DE-5000 is in fact not a typical resistance checking mode used by a DMM but rather a special mode of the DE-5000 which can measure ordinary resistors as well as capacitor ESR due to the fact the DE-5000 uses AC (e.g., 120Hz, 1kHz, etc.).  And despite the fact the DE-5000 uses AC excitation to measure resistance, it's resistance-checking accuracy (for normal resistors, not capacitors) should still be on par with resistivity checking accuracy of high quality DMMs, is that correct?
« Reply #20 on: September 14, 2019, 04:00:32 pm »
After turning on the DE-5000, pressing the "LCR AUTO" button repeatedly gets us to the "Rs" mode.  One more push after that and we arrive at the "DCR" mode.  The "DCR" mode is the same as what a DMM does, but neither the "Rs" mode (AC excitation) nor the "DCR" mode (DC excitation) will have the kind of accuracy that your 6 1/2 digit DMM has.  The accuracy spec of the DE-5000 is given in the user's manual, and it's what one would expect from a low cost handheld device like the DE-5000.
The DE-5000 does quite well for what it is, but it can't compare to a bench LCR meter.
Offline fzabkar
« Reply #21 on: September 14, 2019, 09:35:03 pm »
ISTM that, if you really want a capacitor with ESR, then choose a capacitor with an ESR of 0 and add an external resistor (as has already been suggested). However, be aware that any internal ESR causes heating, which reduces the life of the capacitor. ISTM that the squeal heard by the OP might be due to inrush current, in which case an inductor may be the solution, as well as providing additional filtering.
Offline JDW
  • Country: jp
« Reply #22 on: September 14, 2019, 10:27:20 pm »
But when comparing the accuracy of the DE-5000's "Rs" mode versus "DCR" mode when checking the resistance of normal resistors (not ESR), is there a difference in accuracy?  Or will AC excitation show largely the same resistance value of a given resistor as DC excitation?
Thank you for the suggestion, but as I mentioned before, there is not enough physical space to add such.  And wouldn't adding a series resistor (I still don't know what Wattage would be best, by the way) also add unwanted ESL?  Then again, you seem to suggest that added inductance would be a good thing in this case.  However, I don't know what that inductance value should be.  But again, there's no space to add resistance or inductance (separate from what the replacement capacitor provides inside itself), and trying to add resistance or inductance with SMD parts on the bottom (solder side) part of the board would require an undesired amount of cutting.  Please see my previous post where I provide a link to numerous photos of the PCB so you can see what I mean.
Offline fzabkar
« Reply #23 on: September 15, 2019, 03:43:59 am »
I see that there is already an inductor at L205, but it's on the output side of the capacitor.
There are two links visible on the underside of the PCB. Would it be feasible to replace them with a single, axial, high frequency choke?
Something that looks like this …
https://cpc.farnell.com/epcos/b82111ec20/inductor-axial-7-0uh/dp/FT01259
https://www.tdk-electronics.tdk.com/inf/30/db/ind_2008/b82111e.pdf
« Last Edit: September 15, 2019, 03:50:09 am by fzabkar »
Offline JDW
  • Country: jp
« Reply #24 on: September 15, 2019, 05:26:29 am »
It seems you are suggesting I remove L203 and L205, measure their inductance, then replace them with physically smaller axial chokes of the same inductance such that I would then have more physical space to include a series resistor with C214.  Is that correct?
Even so, I still am not sure how to calculate what the wattage rating of the series resistor should be when doing that.  Do you?
« Reply #25 on: September 15, 2019, 07:50:25 am »
I would expect about the same accuracy for the two modes, except for very small resistances, where thermoelectric voltages can cause substantial error in the DCR mode, whereas the Rs mode is not affected by thermoelectric voltages.
Offline dom0
« Reply #26 on: September 15, 2019, 12:43:02 pm »
I have seen a number of 30-50 year old electrolytics that were still fine (capacity within tolerance, reasonable ESR). Those are usually the plain-aluminium can, often made by Sprague...
You can also buy capacitors now that have life expectancy of 30k hours at 105 °C and 30 years at 50 °C.
The reason so many caps are dying so quickly is aggressive electrolytic, thin films (for capacitance density and ESR), poor sealing and most importantly high ripple currents causing lots of dissipation in them, plus external heat from other components.
« Last Edit: September 15, 2019, 12:45:55 pm by dom0 »
Offline fzabkar
« Reply #27 on: September 15, 2019, 10:32:27 pm »
It seems you are suggesting I remove L203 and L205, measure their inductance, then replace them with physically smaller axial chokes of the same inductance ...
No, I'm suggesting that you remove the two wire links and replace them with a choke. If they are not links, then ignore my suggestion.
Offline JDW
  • Country: jp
« Reply #28 on: September 15, 2019, 11:50:21 pm »
There are indeed 2 separate solid wires with no insulation (they look like staples) on the component side of the PCB in the two locations you point out.  But what inductance value (choke) are you suggesting they be replaced with?  On page 5 of the TDK PDF you linked for me, there are 10 different Lr values that are available.
So your thinking here is to replace the 2 jumper wires with chokes so as to have the chokes adjust the inrush current which you suspect is making the beep/squeal sound I am hearing, thereby allowing use of a low ESR capacitor (my Nichicon UHE1C222MHD1TO) for C214?
« Last Edit: September 15, 2019, 11:58:41 pm by JDW »
Offline fzabkar
« Reply #29 on: September 16, 2019, 12:05:57 am »
Yes, that's the idea. Others would be better placed to suggest appropriate parts. I used the phrase "something that looks like this" because I hadn't done any calculations or extensive searches. The +5V rail appears to have a maximum rating of 2A, so I would choose a choke with a 4A rating. The chokes have their own ESR which you would need to consider. In my case I would be using a trial and error approach, but others might have a more elegant solution. In fact I'm not even certain that this approach would work.
Edit: I'm suggesting that you replace the two links with a single choke, not one choke per link.
« Last Edit: September 16, 2019, 01:48:36 am by fzabkar »
Offline JDW
  • Country: jp
« Reply #30 on: September 16, 2019, 04:28:56 am »
As someone who faces similar search troubles when designing electrolytics into new designs...
exmadscientist,
Since you seem to be an experienced power supply design engineer, what are your expert thoughts on the suggestion of fzabkar to use a single axial choke inductor in place of two wire jumpers (as discussed in the last couple posts)?  (My concern is that would more fundamentally change the original design than simply finding a replacement capacitor for C214 that has higher ESR & Dissipation Factor.)
« Reply #31 on: September 16, 2019, 07:03:50 am »
If you use a moto-tool or exacto knife to cut away some of the copper foil around one of the pads where your capacitor is soldered in, there appears to be room to add a small value (.1 ohm or .05 ohm) resistor in series with the capacitor, allowing you to adjust the ESR to suit.  Of course the resistor has to be able to handle the ripple current with overheating.
Offline Shock
« Reply #32 on: September 16, 2019, 08:37:16 am »
Is there any reason you can't just use a standard cap series? Going for the high impedance long life series and moving up from 10V to 16V is lowering your ESR.
ESR is also commonly measured at 100kHz.
Multimeters: Fluke 87V, 117, 27/FM     >>> Fluke 51/52 Thermometer Parts Required <<<
Oszilloskopen: Rigol DS1054Z, Phillips PM3065
Offline JDW
  • Country: jp
« Reply #33 on: September 17, 2019, 12:58:00 am »
I just made the following measurements today...
DE-5000 "Rs-mode" Measurements using Calibrated TL-21 adapter.
Rubycon 10V 2200uF capacitor (SH series)
No beep/squeal at power-on (when soldered into HD20SC PSU as C214)
ESR@100Hz: 0.20Ω
ESR@120Hz: 0.19Ω
ESR@1kHz: 174mΩ
ESR@10kHz: 159mΩ
ESR@100kHz: 145mΩ
LCC 25V 2200uF capacitor (new but 16+ years old)
No beep/squeal at power-on with the same ripple & ESL spike levels as Rubycon cap.
ESR@100Hz: 0.04Ω
ESR@120Hz: 0.03Ω
ESR@1kHz: 27mΩ
ESR@10kHz: 24mΩ
ESR@100kHz: 23mΩ
Nichicon 16V 2200uF capacitor (UHE1C222MHD1TO)
Beep/Squeal at power-on & measured higher amplitude ESL spikes on scope.
ESR@100Hz: 0.02Ω
ESR@120Hz: 0.02Ω
ESR@1kHz: 10mΩ
ESR@10kHz: 9mΩ
ESR@100kHz: 7mΩ
Now let me know what you think.
Honestly, I am inclined to go with a higher ESR "new" replacement cap for C214 because it is the simplest solution overall that most people can do, and I intend to share this info with other who wish to recap the same board in like manner.  Cutting the PCB and soldering SMD resistors isn't desirable for most people.  And while the axial lead inductors may work (I still want to hear from exmadscientist about that), again, the simplest solution would be a replacement radial lead capacitor.  And I cannot recommend my LCC cap because they aren't sold anymore, so I will buy the following caps, and test them to see which I prefer to recommend to others performing recap jobs:
SEK222M010ST
228CKS010M
I was going to buy the following Panasonic cap too per the recommendation in this thread, but there's an oddball warning atop the datasheet that says "This series is no longer available for purchase in the country of Japan."  What the heck!?
EEU-EB1A222
« Reply #34 on: September 17, 2019, 03:49:47 am »
exmadscientist,
Sorry, I'm not a power supply specialist, though I do work on them. I'm not willing to speculate on the effects of replacing wire jumpers with chokes, absent having a schematic. If it were my repair, I'd just find an appropriate electrolytic capacitor and call it done.
(And no, I most certainly have no idea why Panasonic is not willing and/or able to sell certain capacitor series in Japan any longer. This appears, judging by a PDF of theirs, to have started sometime around July and affects most of their through-hole electrolytics and none of their surface-mount parts, if I am interpreting that star correctly.)
Online james_s
« Reply #35 on: September 17, 2019, 04:14:09 am »
I've had a lot of surface mount electrolytics leak and cause damage, but with the through-hole capacitors it has been extremely rare. In cases like this I leave the originals alone unless they test bad or show signs of leaking or bulging.
Offline JDW
  • Country: jp
« Reply #36 on: September 17, 2019, 10:24:01 am »
Here's a short video with sound:
https://youtu.be/FlD3kzvnerM
The first part of the video shows the recapped HD20SC PSU but with the stock Rubycon at C214. The second part of the video shows the waveform and beep sound with the Nichicon replacement at C214.  You can see the frequency of the beep is just over 1kHz.
And as I mentioned before, with my 16+ year old LCC cap at C214, there's no beep and the ripple and ESL spikes are almost identical to what you see with the stock Rubycon cap.
Online Zero999
  • 0999
« Reply #37 on: September 17, 2019, 04:11:40 pm »
I agree. It's daft to replace the capacitors, when it's not necessary and the fact that it doesn't work so well indicates it was a bad idea. The original poster should just go back to the old capacitor and leave it alone.
Online james_s
« Reply #38 on: September 17, 2019, 04:51:42 pm »
This has been a problem in the vintage arcade collecting community as well. A lot of people will take a working monitor or one with minor problems and take the shotgun approach replacing all of the electrolytics, and often the flyback and HOT with inferior Chinese replacements and then they are surprised when the monitor doesn't work properly. There are times when it makes sense to replace old parts as preventative maintenance but when doing that it's important to really understand the details and not just blindly assume that newer = better.
Online Zero999
  • 0999
« Reply #39 on: September 17, 2019, 06:12:59 pm »
I agree, except the original poster clearly isn't using fake parts, but superior ones with a lower ESR than the device was originally designed for, hence the oscillation.
The old/crappy capacitors with a high enough ESR seem to becoming harder to find, hence the original poster finding they're obsolete, so considering a solution such as a series resistor, when the capacitor does need replacing is probably a good idea, but for now: if it ain't broke, don't fix it!
Offline Shock
« Reply #40 on: September 17, 2019, 08:59:48 pm »
If the new standard cap resolves the problem and the supply remains stable after testing etc I don't see a problem. It's not totally pointless as it will help someone else if they get the oscillation problem or dead caps to know what works, got to do proper RCA ;).
JDR take a measurement of the new caps you get, don't bother anything but 100kHz.
Offline JDW
  • Country: jp
« Reply #41 on: September 18, 2019, 12:03:20 am »
"JDW"? :-)
What do you mean by "don't bother anything but 100kHz"?  If you meant to say "don't bother MEASURING at any frequency other than 100kHz," could you please explain why?
Offline JDW
  • Country: jp
« Reply #42 on: October 03, 2019, 06:05:09 am »
I purchased 3 capacitors from Mouser, and measured data using my DE-5000:
Illinois Capacitor 228CKS010M 2000hr@85°C:
ESR
@100Hz = 60mΩ
@120Hz = 50mΩ
@1000Hz = 43mΩ
@10,00Hz = 39mΩ
@100,00Hz = 42mΩ
DF@120Hz = 0.090
Capacitance = 2.11mF
Q@120Hz = 11.04
θ@120Hz = -84.7°
Panasonic EEU-EB1A222 10,000hr@105°C:
ESR
@100Hz = 90mΩ
@120Hz = 90mΩ
@1000Hz = 80mΩ
@10,00Hz = 74mΩ
@100,00Hz = 65mΩ
DF@120Hz = 0.152
Capacitance = 1.95mF
Q@120Hz = 6.5
θ@120Hz = -82.0°
Cornell Dubilier SEK222M010ST 2000hr@105°C:
ESR
@100Hz = 40mΩ
@120Hz = 40mΩ
@1000Hz = 31mΩ
@10,00Hz = 29mΩ
@100,00Hz = 27mΩ
DF@120Hz = 0.070
Capacitance = 2.06mF
Q@120Hz = 14.13
θ@120Hz = -85.8°
I soldered each of the above into my power supply and tested the resulting ripple and ESL spikes on my scope.  None of these 3 caps caused the audible 1kHz beep sound at power-on, which was nice.  Surprisingly, the highest ESL spikes came from the Panasonic, and the ripple was higher than any of the other capacitors (due to its ESR).  It's rated for 10,000hrs but the ESL spikes were much higher than the other 2, so I won't be using it.  Ripple and ESL spikes were almost the same for the Illinois and Cornell caps.  I intend to use the Cornell due to its 2000hr@105°C rating versus 2000hr@85°C for the Illinois, and for its lower ESR and higher Q.
So the moral of this story is that its difficult to know which cap is best without testing.  I had thought the Panasonic would win, but due to the higher ESL spikes it produced (which still somewhat baffles me), it was put out of the running.
Thanks to all who contributed to this thread.
« Last Edit: October 07, 2019, 02:27:37 am by JDW »
