I just made the following measurements today...
DE-5000 "
Rs-mode" Measurements using
Calibrated TL-21 adapter.
Rubycon 10V 2200uF capacitor (SH series)
No beep/squeal at power-on (when soldered into HD20SC PSU as C214)
ESR@100Hz: 0.20Ω
ESR@120Hz: 0.19Ω
ESR@1kHz: 174mΩ
ESR@10kHz: 159mΩ
ESR@100kHz: 145mΩ
LCC 25V 2200uF capacitor (new but 16+ years old)
No beep/squeal at power-on with the same ripple & ESL spike levels as Rubycon cap.
ESR@100Hz: 0.04Ω
ESR@120Hz: 0.03Ω
ESR@1kHz: 27mΩ
ESR@10kHz: 24mΩ
ESR@100kHz: 23mΩ
Nichicon 16V 2200uF capacitor (
UHE1C222MHD1TO)
Beep/Squeal at power-on & measured higher amplitude ESL spikes on scope.
ESR@100Hz: 0.02Ω
ESR@120Hz: 0.02Ω
ESR@1kHz: 10mΩ
ESR@10kHz: 9mΩ
ESR@100kHz: 7mΩ
Now let me know what you think.Honestly, I am inclined to go with a higher ESR "new" replacement cap for C214 because it is the simplest solution overall that most people can do, and I intend to share this info with other who wish to recap the same board in like manner. Cutting the PCB and soldering SMD resistors isn't desirable for most people. And while the axial lead inductors may work (I still want to hear from
exmadscientist about that), again, the simplest solution would be a replacement radial lead capacitor. And I cannot recommend my LCC cap because they aren't sold anymore, so I will buy the following caps, and test them to see which I prefer to recommend to others performing recap jobs:
SEK222M010ST228CKS010MI was going to buy the following Panasonic cap too per the recommendation in this thread, but there's an oddball warning atop the datasheet that says "This series is no longer available for purchase in the country of Japan." What the heck!?
EEU-EB1A222
