Author Topic: Old transistor replacement for Fronius Transarc 500 (Castolin Transmodul 500)  (Read 1685 times)
Offline dziacialTopic starter
Can anyone help me find replacement for old ESM2893V transistor. It was used in Froniu Transarc 500 (Castolin Transmodul 500) welder. It look like this:
Maybe someone have service manual for this welder?
Offline coromonadalix
They where used in arc welders   =   NPN power darlington   28v at 93 amps
I think sgs thomson have equivalents ??
They were similar to ESM2030DV on another thread,  some one had 14 of them to sale in 2008 ?  or an esm 3045dv  as a substitute ???
Only links ive found : http://www.sabaelec.ir/products_new.asp?groups=315&gname=ISOTOP%20Transistors&mname1=Transistors
Mouser have this pdf :  https://www.mouser.com/ds/2/389/esm3030dv-954688.pdf
https://www.mouser.com/ProductDetail/STMicroelectronics/ESM3030DV?qs=%2fha2pyFaduiVw8R86C0rzL9R%2fJHzywOFQfAGTeyHdMw%3d
30$   zero in stock ???
They are in end of life warning
You have this one,  36 parts left, and the price is +/- 60$
https://www.mouser.com/ProductDetail/STMicroelectronics/ESM6045DV?qs=sGAEpiMZZMshyDBzk1%2fWixbhOhHbn%2fdrv65Jk3f%252bGm0%3d
If you search this : NPN DARLINGTON POWER MODULE
Google fuu wil show you some results, you have some modules on ebay ...  its the datasheet who's hard to get ?
good luck
« Last Edit: October 30, 2018, 10:35:32 am by coromonadalix »
The following users thanked this post: dziacial
